#1 | |
Audio Junky
Symptoms could include, weird rpm fluctuations, dash or headlight dimming, slower than normal starts when you turn on your car. There was another write up that was pretty good that I no longer find anymore, it showed the math behind the discharge of a cap... Basically It came down to a 1farad cap would only be able to power a 1000w amp for something like 1/10th of a second, and then its power is used up, and then becomes a drain on the system... That is where Richard Clark's article picks up. If a cap is being fully discharged, you've got bigger problems than a cap can fix. To answer the question about headlight dimming... yeah, a cap will make it appear that your head lights don't dim as much. The reason for that is because your lights won't be getting as bright. They will stay dimmer, longer, and thus you won't see as big of a fluctuation, because there will be a constant drain on your electrical system. |
#2 | |
Please explain the mechanics of phantom energy to me. Where does this drained energy go? (besides resistance) Finally, you should release these results to the thousands of stereo shops that recommend caps. Along with all those people winning stereo competitions. Oh the people making the caps will probably want to know too. I think I'm gonna stick with the millions of articles that say caps work, rather than the ONE that says they don't. |
#3 | |
Audio Junky
I have yet to see a single SPL vehicle at world finals run any caps. They have crazy sponsorships that allow them to pick them up for cost. There is a reason why they don't run them. All the non-believers can go to some actual car audio forums, elitecaraudio.com, and soundsolutionsaudio.com are two decent forums. Car shops make money on them, they make all their money on accessories.. Decks and speakers bring them almost no profit, its connectors, caps, and wiring that they get their profit from. Why stop selling a product that pays the lease on your building? there are also articles, RECENT ones that say likewise, Also, it takes NO education, not even a highschool diploma to open a audio shop, or to be the head installer. Try talking to an electrical engineer who has actually studied the science behind the problem, and is familiar with car electrical systems. If nothing else, adding a cap to the electrical system adds two more connection points which add resistance, and thats before you even add in the internal resistance of the cap itself. STORAGE MEANS NOTHING if the power plant can't keep up. Eventually the storage will run out. CAPS are storage... and a very small storage at that. Anything more than what is built into the amplifier is overkill, and will not help you at all unless you already have a power plant (alt) that can keep your storage (bat) 100% full 99.9% of the time already. If you fit that situation... then you won't have significant voltage drops at all, but you will still have very minor fluctuations (talking in the range of a tenth of a volt or less). In that situation... yes, a cap will help stabilize the voltage the way it is supposed to. But, is +/-.05v worth $100 or more per farad? People who have light dimming are most likely seeing dips of 1.5v or more already, just for refrence. For those who swear caps stopped their lights from dimming... did you have volt meters recording your voltage real time? Did you have light sensors watching the output of your lights... did you do A/B comparisons? If not, then admit that your "real world experience" is very possibly incorrect, and flawed with bias. I can't think of a better quote to describe this situation other than... "We live in a society exquisitely dependent on science and technology, in which hardly anyone knows anything about science and technology." -Carl Sagan Last edited by talnlnky; 02-16-2009 at 01:31 PM. |
#4 | |
Audio Junky
From my experience, most people with subs in their cars have at one time or another taxed their electrical system too much. Most people who have subs fall in the category of 16-24 yr old males, and too often than not, try to put as big of an amplifier as they can in their car without doing any math to see if the car can handle it. For people running less than 600rms TOTAL in their car on a stock electrical, yeah, a cap probably won't hurt. But i've met more people who run more than 600rms to their sub(s) alone, than not. Oh yeah... and about your statement about caps not being a load on the system... why is it then that if you leave a cap for a day they lose their charge mysteriously... You charge something, and instantly its already losing its charge, even without using it. My statement remains, caps are the icing on the cake, upgrade the alt, all cables, and battery before even thinking about a cap. |
| center caps for enkei rpf1s??? | andruboz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 06-05-2010 10:37 PM |
| How to put center caps on wheels w/o breaking them? | TitaniumBarbell | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-09-2009 06:29 PM |
| FS: Stock LB wheels, tires, caps 2K mi, NorCal | JosephDoc | Items for Sale by private party | 1 | 09-20-2007 03:09 PM |
| Need Help on finding 15 inch Hub Caps | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 18 | 03-31-2007 01:12 PM |
| WANTED - Stock 15" 2007 Yaris HUB CAPS! | Chris07LB | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 06-29-2006 07:09 PM |
