Old 02-18-2009, 09:54 AM   #1
Originally Posted by dobsona View Post
Thanks for replies. Like the idea of teeing into the ignition circuit rather than using the battery. This could solve two problems, 1. leaving the lights on, 2. as we drive in Italy and it is obligatory to have lights on day and night, it would then be possible to leave them switched on.
As I do not have a wiring diagram at present, could you please indicate which wires need to be changed (which colour are they?) and where they are located.
Thanks agin for your help.
I did some experimentation last night with the headlights off with the ignition. The headlight dimmer switch connector is shown below:
ED is the common for the headlight switch (which actually provides power to the headlight relay's coil). I thought that opening it would turn off the headlights, and it does, but the parking lights remain on and the light reminder buzzer still buzzes. There is another circuit which also needs to be opened as well:
T1 is the common for the parking lights and the feed to the light reminder circuit for the instrument cluster. It also needs to be opened.
With a dual pole (DPST or DPDT) relay (12 VDC coil, 10A rated contacts) this can be accomplished:
The coil gets connected between the white wire on the ignition switch connector and a ground.
One set of normally opened contacts gets connected in between the headlight dimmer switch connector and the ED wire (wire gets clipped and the relay contacts are inserted in-line).
The other set of normally opened contacts gets connected in between the headlight dimmer switch connector and the T1 wire (wire gets clipped and the relay contacts are inserted in-line).
I only had SPDT relays laying around, so once I pick up a dual pole relay I'll do a better write-up with pictures...
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
Dueling drivers GeneW General Yaris / Vitz Discussion 37 01-25-2009 06:32 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
Smoke your own tail lights ChinoCharles Cosmetic Modifications (Exterior/Interior) 9 01-15-2007 11:00 PM
