Old 02-18-2009, 08:15 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Theres this one thing called netipot but they make a squirt bottle nasal rinse version. Comes with a packet of powder you put inside and lukewarm water and then you squirt it through one nose and comes out the other. You will feel tons better and completely clears your sinus. Its good for people also who suffer from severe allergys. Works better than any noise spray or tablet medicine and you will have clear sinuses if you use it every day for the rest of your life.
Also there is a cough drop called cold eeze that has zinz and some other stuff thats proven to reduce the recover time from a cold.
I personally do not like sudafed the way it drys up your nose. For some reason whenever i use sudafed for several days when i have a really bad cold it always turns up into a nasal infection which is even worse.
With sinus rinse you feel immediate relief and makes getting through a bad cold a breeze. Plus its cheap and comes with liek 100 packets so youc an use it later whenver you get sick again.
Old 02-20-2009, 12:26 AM   #2
GeneW
Drives: 2008 Yaris
I heard about it, it's an Indian Vedic healing technique.
I don't like using things like that under ordinary circumstances but they might be good for disease.
Gene
Suggestions for $300-$400 worth of mods please! CtrlAltDefeat Performance Modifications 51 01-05-2011 10:15 AM
Need some suggestions Qmobile Performance Modifications 10 10-20-2008 11:14 PM
Suggestions for Good Yaris Spring and Damper Combo jdmHQ Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 08-03-2007 11:23 AM
What do you guys think? any better suggestions? BMGYaris DIY / Maintenance / Service 3 11-13-2006 11:50 AM
Skirts too low,Ne Suggestions David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 08-21-2006 01:44 AM
