Old 02-20-2009, 08:54 PM   #1
SEVEN
Drives: 07' HB Black
basic "autocross setup" springs... if you're gonna autocross, and you've installed lowering springs, please get a set of shocks that were built to be coupled with a lowering spring. stock struts and "lower" springs just don't fit into autocross land.[/size]
will tein s.techs and trd shocks work???
When life passes you by ... dowshift
SEVEN is offline   Reply With Quote
Old 02-20-2009, 09:16 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
What you'll eventually conclude with that setup and really think about it is that a) you don't have enough suspension travel so you bottom out both in hard turns and over bumps and b) the shocks don't sufficiently control the motion of the springs on rebound.
Will it "work"? Yes, but not if you want the car to handle as good as it could.
2007 Yaris Unveiled at 2005 SEMA Show YarisBueller General Yaris / Vitz Discussion 0 01-12-2006 05:28 PM
