Here you go...
seems pretty substantial... nice case and everything...is it really a whole chip? ![]() and.... and.... ![]() NO CHIP!! just a resistor. ![]() The packaging and the contents -- too funny:
That is a riot! Where did they have you connect said "chip"?
It's quite sad as well that they don't even solder the resistor to the wire - just twist the leads around the wire. |
#3 | |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
It's called wire wrapping and it's actually a technique that's used often in smaller electronics... |
![]() ![]() Drives: 07 yaris hatch Join Date: Jul 2009
20 cent resister , $19.80 for the box and a bit of wire , sounds like a bargin , so how many are you going to hold in stock , for the honda guy's of course. ![]()
#8 | |
§†ęĄ¶‡Ћ-NCP96
that 33k resistor is actually only 8 cents http://mouser.com/Search/ProductDeta...L53UfNMqu4M%3d 2 cents if you buy a reel of 5000. |
#9 | |
Thats 8 cents US so in kiwi ($ New Zealand) terms its close to 20 cents
#10 | |
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
Learn to Relax
[QUOTE=cali yaris;247637]Here you go...
seems pretty substantial... nice case and everything...is it really a whole chip? NO CHIP!! just a resistor. ![]() The packaging and the contents -- too funny: Thanks Garm for your help in making us wiser.
#13 | |
Yaris Koolaid drinker
Drives: 2008 Blue Yaris 5-door Join Date: Nov 2008
![]() Not just any resistor, Its a 33k ohm 1/2 watts resistor! Cost about $0.01 each from digikey. -------------------------------------------------------------------------------- Edit: note to self, read entire post before posting a response that may be similar to others. |
| The Yaris Performance Primer | eTiMaGo | Performance Modifications | 30 | 01-24-2024 04:26 AM |
| Performance Chip or Rip off??? | MoeStylez | Performance Modifications | 28 | 10-02-2010 08:46 AM |
| Performance Chip | njyaris | General Yaris / Vitz Discussion | 5 | 07-04-2007 12:19 PM |
| Yaris Performance Specs | neohalo | Performance Modifications | 22 | 06-24-2007 08:46 PM |
| Performance Chip *to funny* | Imagine | Off-topic / Other Cars / Everything else Discussions | 11 | 05-04-2007 01:22 PM |
