#1 | |
DIY - rear sway bar [pics]
Today we installed an Ultra Racing rear sway (anti-roll) bar on Babie Y's Yaris. I took a few pics, hope this is helpful.
First, jack up the back of the car (from the sides) and remove the rear wheels. This makes it easier to get to the bolts later. Then, get out your sway bar. A friend, helper, bodyguard or whatever helps. ![]() Look under the car. There is one large bolt holding the bottom of the rear shock. You can re-use this bolt. There is also a hole that isn't being used just in front of it, like this: ![]() Here is the same two holes, shown from the inside angle instead: ![]() Remove the bolt holding the shock. Place the swaybar with the bar at the bottom and so the holes line up. Re-install the bolt through the shock, then the sway bar, then a washer and nut. ***It is easier to do both shock bolts first, leaving the sway bar hanging -- then do the two front bolts. That should look like this: ![]() And like this: ![]() Tighten and/or torque the nuts and you're done. In another thread there was consensus that "making them tight, but not crazy tight" was good enough for this. thanks to supmet: Quote:
* (check and re-tighten, if needed after driving for a few days). * the Ultra Racing sway bar comes with hardware -- I'm sure the TRD one does, too. * Yes, that is a Tokico shock.
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 03-08-2009 at 01:03 PM. |
Sweet. Thanks for the write up, Garm. I might be working (no, not the work I'm doing now, but actually be getting paid for working) this summer in addition to my summer classes. This will be one of the things I'll be getting if I get the position at the hospital.
Bathroom + Laptop = <3
Question though, does it really make a compareable difference over stock, and i don't know if you sell both of them would you recommend the Ultra or the TRD one? They are both at a competitive price..
The yaris is lowered on 17's, and she likes to take corners hard... I'm going to do some research on it, just wanted to hear it out of the mans mouth first hand |
It looks
just like the TRD one except it's WHITE ![]() so if you want RED you have to pay more ![]() dam i should have waited a couple of months and just paint it RED
#5 | |
Yes, this bar makes a big difference in cornering. Out of all the "bracing" and "bars" this is the one to get first and the one you will feel. I think TRD is overpriced, but as a customer, it is good to have choices in the marketplace.
argh i gotta get one of these someday
nice writeup!
Drives: 2007 4 Door Yaris Join Date: Jan 2009
For the TRD bar, the torque specs are 36 ft/lbs on the bolt at the bottom of the suspension, and 44 ft/lbs for the other bolt.
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
what is the price for the ultra racing sway bar?
nevermind, found an older thread. $129 shipped.
thanks for the torque specs, added to first post
@cali: can you source unpainted (maybe just primered) bars?
Also, how thick is this bar compared with TRD?
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
Ultra Racing 19mm, TRD 22mm (I'm told) -- I've tried both, can't really feel much of a difference.
Thinking about having them make a 23mm bar to play with. Why would you want an unpainted bar? You can always re-paint it anyway?
2008 Prht Miata Red
Drives: 2009 3D 4AM PWR Pkg, Yel Jolt Join Date: Feb 2009
Ultra Racing Rear Sway Bar
I bought my UR Rear Sway Bar from Cali Yaris, it shipped fast, received it very quick. It is easiest to put it on the way Cali Yaris describes. A small Pry bar will help to spread the bar and get it into place.
Driving: I noticed that the suspension felt Firmer and not bouncy as it was before, it remove the wander that this car has. Iam not constantly stearing to stay straight. The Wander is mostly gone. The car feel's more solid. Handling: The handling is much improved, I feel that acident avoidance is greatly improved. The car still has a slight amount of wander, maybe it's in the front end?? My Car has the Electric upgraded package that includes the upgraded Goodyear tires, not the Bridestones. The GoodYear tires hold the road better, and are allot quieter with less road noise coming into the car through the tires. G |
#14 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I've never experieced rubber with less braking grip than these LS. They actually feel better in wet roads than dry???????? The ABS is singing!
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#15 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
meh.... when I installed the wife's TRD bar I just left the shock bolts facing the installed way and placed the new bolts facing the opposite way....
good write up GARM! |
#16 | |
I think that's what it showed in the diagrams in the instruction sheet.
Never take eyes off opponent - Bruce Lee |
#17 |
![]() ![]() Drives: 09 Yaris hatch, Meteor Metal Join Date: Dec 2008
Installed my Ultra sway bar a couple of weeks ago. man the handling is improved. i can really toss that little car around. (not too much still a bit of ice, and i have my snow tires on)
install was a snap. though i didn't tighten the shock bolt on the left side down all the way (got distracted) and was getting a horrible thunk sound. easy fix. |
#18 |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Very nice , I still need to get one of these sway bars off you Garm .
Garm is permanently high because he is the king of smokin' deals! |
| Rear Sway Bar Instructions - Additional Pics | SeaYa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-26-2009 01:05 PM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD Rear Sway Bar Install ?? | bikegerm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 12-26-2008 01:46 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| DIY - TRD rear sway bar | kurokoma-kun | DIY / Maintenance / Service | 0 | 10-20-2008 01:21 PM |
