Yes- I fit in it.
Installing power windows and locks
I just spent an hour looking for a post that I saw back in the summer about a DIY install of the A1 electric window and lock kits. I can't seem to find that post anymore, was that deleted in a data problem, or?
If so, does anyone have a copy of that saved anywhere? |
aka SDMF
the only hard part about it is fishing the wires, instructions are pretty simple to understand. heres a pic of my naked door with the kit. hope that kinda helps.
Yes- I fit in it.
Hey, thanks.
Yea, I can see the frustration by the exclamation written with a Sharpie on the door :) Can I ask... when did you do the upgrade, and does it work and hold up well? Did you use one of those "add a fuse" systems and run power off of the fuse box? Also, did you need the switches for the door locks, or is using the existing manual switches ok? |
First time DIYer
i wish i had seen this sooner. i'm now on day 3 of putting JUST the power locks in and am having one hell of a time doing it. it appears i have the kit for a rod-style mechanism that i picked up from pep-boys; not the cable one. hwhoops.
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
#5 | |
aka SDMF
First time DIYer
staypuft, when you put the lock actuator in, did you have to remove the styrofoam that was attached to the door panel? it seems that's the only way i'm getting mine to fit in and work properly..
aka SDMF
yep you gotta do alot of shaving, just use a hacksaw blade, i had to cut some of the insulating foam as well for some clearance issues
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Can you guys post where you got these kits at? I'd be interested in the power locks. (is it keyless entry?)
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
First time DIYer
actually, i picked mine up from my local pepboys for, i think, $13 each. the only caveat to that was that they're for the rod style locks, not cable. i don't think they carry the cable style ones in stock. i had to do some tinkering and playing around to get the first door working (took 4 days!), i was able to do the other door in under an hour.
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
what brands/companies of power windows/locks did you get? *for reference since I need to do this*
First time DIYer
i'll stop by the store today and find out the brand. in the meantime, here's a picture of one of them installed. again, since i got the wrong kind, i had to do some makeshift work, but imo, it works just as well!
Any update on what kits you got at pep boys?
#14 |
![]() ![]() Drives: 2008 Red Yaris LB Join Date: Nov 2008
heh, looks pretty hard to drag the cables to the center console.
#15 |
First time DIYer
wow, i guess this is what happens when one unsubscribes from a thread.. sorry for the delay! i stopped in pep boys to find it and to my surprise, there wasn't a brand name on the box... it just says "Power Lock Actuator" on it.. pep boys brand, maybe? lol but everything that i needed, except the extra wire, came in the box - mounting hardware, actuator, instructions, etc.
i didn't install a switch for the locks, though, and after a month or so with having the power locks, i've decided to do that... I just have to figure out which wires go where.
#16 | |
#17 |
How would get the hatch to lock, or is there a special actuator from toyota. Cause I read the DIY rear hatch door lock and your gonna have to do some modding to get it to fit.
#18 |
First time DIYer
most likely. i haven't cared enough about it to look into it, but i remember pep boys having an actuator for that, as well... if you couldn't tell, i do most of my parts shopping there lol
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| power locks and whatnot | thatboyjer | In Car Entertainment + Electronics (audio / video / alarm) | 9 | 07-31-2007 11:45 PM |
| Aftermarket Power Windows?? | blazerscoach | New YARIS Purchase Forum | 7 | 02-18-2007 06:49 PM |
| The power upgrade thread | ChinoCharles | DIY / Maintenance / Service | 19 | 09-27-2006 03:14 PM |
