Old 10-09-2006, 11:12 AM   #1
Ayka
Drives: 07' Yaris HB | Blazin' Blue
does the Fuse Box handle grounds as well? Im having trouble figuring out where to ground these two as well...
/sigh, Jump right in =P
Ayka is offline   Reply With Quote
Old 10-09-2006, 11:40 AM   #2
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The fuse box I used is on the bottom of this:
You don't need to remove the little compartment to get at it, this just helps you see it.
There is a cover on the bottom that you remove to reveal the fuses. That's the cover that won't go back on with an add-a-fuse in place.
For grounding you'll need a bolt or screw to metal someplace. Without crawling around under the dash, I can't give you any ideas right now.
Old 10-09-2006, 12:11 PM   #3
Ayka
Ok, so the fuse connects on the Bottom Portion of that panel.. I think I can do this.
and I expect to install my own sound some day... I'll learn!
Thanks Violin
Old 10-11-2006, 04:48 PM   #4
Ayka
You need to make sure that it is the MINI-FUSE for Add-a-Fuse, I accidentally got some of the regular sized suckers, and well.. time to make a return!
Mine look exactly like that, but they were Bussmann Add-a-Crct, work like a charm
Old 10-11-2006, 04:49 PM   #5
Violin
Violin's Avatar
I'm note really a fuseologist, but there are two sizes of blade fuses. Ours is the smaller size - that's what I used.
Old 11-04-2006, 07:00 AM   #6
mcdaddy
mcdaddy's Avatar
Drives: Yaris 2006, 2NZFE 1.3L
this is what i did during the last weekend..
it helps me see my toe nails cleaned all the time.. hahaha
mcdaddy is offline   Reply With Quote
Old 11-05-2006, 11:56 AM   #7
BMGYaris
Drives: Yaris 3dr Hatchback
Hey guys, i am looking for some LED under dash kits that have a switch that can turn them on and off and are super eas to install...but preferably dont use the cig lighter as that just looks too ghetto for me (couldnt just sneak them on when a girl gets in the car, she would know i was doing it on purpose). but, while i was a student electrician for one year in college all i did was change out ballast (sp?) and fix exit signs and some power outlets, i have NEVER touched anything in my car, too scary for me. Anybody know a good set to buy in paritcular or can i just pick up anything like this http://www.oznium.com/meteor Anybody know a good diy, im pretty darn nervous about messing with wires in my car.
BMGYaris is offline   Reply With Quote
Old 11-07-2006, 05:35 AM   #8
mcdaddy
mcdaddy's Avatar
mine turns ON when the driver or the passenger door opens then turns OFF when the door's close. just hook-up the negative wire of the LED to the negative wire/switch from the door, just make sure that the supplied positive line is the same as the dome light.... viola!!
get yourself a test light to help you out the DIY .. goodluck!!
Old 11-07-2006, 10:22 AM   #9
Violin
Violin's Avatar
If you did that electrical work, you shouldn't really have a problem with your car. At least 12 volt can't kill you.
If you pull the trim off the a-pillar on the driver's side, you can access the wires to the dome light. They're wrapped in electrical tape so you'll have to peel some of that back. The blue wire is the power and the white wire with the black stripe is the ground controlled by the door switch. Many of the circuits on the Yaris are backwards like that - the power is always on and the ground is switched.
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
Interior Light Kit... for Canadian version?! Jem_hadar Cosmetic Modifications (Exterior/Interior) 5 08-17-2006 02:20 AM
Any front bumper/ hood stone chip issues? Where could I get Clear Bra kit? tifosi360 General Yaris / Vitz Discussion 9 08-07-2006 02:43 PM
