Old 02-23-2009, 06:34 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
Originally Posted by Tonavi View Post
I promised I've searched for hours and haven't found anything on this!
I installed an AutoMeter 3-3/8" tachometer and now want to add water temp and maybe oil temp gauges, too. I'd be doing an a-pillar pod.
Before I buy anything, I want to know how the water and oil temperature gauges are installed. The tach was easy; it plugged right into the ECU. I'd think that the water temp would be the same way since it's monitored by the computer. For the oil temp, there must be a sensor that I can tap into for a reading.
Has anyone installed a water oil temperature gauge (NOT the Scan Gauge) in their Yaris, and how did you do it?
I'd love to see pictures if possible.
Thanks YW!
im sure theres a stock water temp sensor you could tap into. or u could get an adapter and cut into a coolant line and stick the adapter and the gauges sensor into that. u'll have to drain ur coolant if u do that.
y do u want oil temp?
oil pressure would be more useful. and a sandwhich plate would make this a very easy install. when u go to change ure oil before u put the new filter on u stick the sandwhich plate on and then the filter goes on the sandwhich plate. the sandwhich plate from glowshift has like 3 or 4 places to plug in a pressure sensor, oil temp sensor, and u could even add lines for an oil cooler if u wanted
Old 02-23-2009, 06:36 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Why not just put in a scangauge or something similar .
Old 02-23-2009, 06:44 PM   #3
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
They aren't as easy to read instantly and since I already have the tach, I'd like to maintain that same style. I like how much info the scangauge tells you from one port, though. Do you know if there's an alternative that's just as useful?
Tonavi is offline   Reply With Quote
Old 02-23-2009, 07:10 PM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Your probably right there , and i must admit , the above pictures look bloody awsome
would love to do something similar , but as it is the wifes car and my toy ,
a comprimise is what i have to deal with ,
as in her words it's like seating in a fighter plane cock pit . to much to look at .
Old 02-24-2009, 09:28 AM   #5
Tamago
Tamago's Avatar
Drives: UZJ100
if you want oil pressure, get it from the same place the stock ecu gets it.. on the front of the engine.
Old 02-24-2009, 04:45 PM   #6
jaserhunter
jaserhunter's Avatar
Drives: 2008 yaris LB
if you add the gauges will you lose your airbag?
"Igitur qui desiderat pacem, praeparet bellum."
jaserhunter is offline   Reply With Quote
Old 02-25-2009, 10:18 PM   #7
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
... and a sandwhich plate would make this a very easy install. when u go to change ure oil before u put the new filter on u stick the sandwhich plate on and then the filter goes on the sandwhich plate. the sandwhich plate from glowshift has like 3 or 4 places to plug in a pressure sensor, oil temp sensor, and u could even add lines for an oil cooler if u wanted
Ok, I'm being lazy and don't want to do my own research. Do you have a part number for the sandwich plate that fits the Yaris?
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
ebay a pillar gauge pods KSIbucky Cosmetic Modifications (Exterior/Interior) 2 07-16-2007 11:47 AM
a-pillar gauge pod 07typeS Cosmetic Modifications (Exterior/Interior) 36 06-17-2007 08:53 AM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 10:41 AM
