Any oldschool obd1 mechanics here i need help with a diagnosis
So story goes my friend has a 93 lexus gs300. I did a seafoam intake manifold cleaning for him. Next day he says his car is shaky at idle. I take it for a test drive and can feel what he is talking about. So i attempt another cleaning thinking that maybe a piece of carbon broke off and reattached itself to a valve. This time the car is worse now and occasionally stalling at idle. But luckly check engine light is on. It has a code 31 something to do with VAF sensor which i guess is a MAF sensor. I remove it and attempt to clean it with electrical contact cleaner but no change.
I assumed the massive amount of smoke went back up the intake and contaminated the sensor. I checked the price for a new one at lexus and wholesale cost is over 800 bucks. I ordred a used one on ebay and threw it in and car is doing exactly the same thing. I am about to remove the throttle body and try to clean all the crap out and clean the idle air control valve. But i really dont want to go through all the work. Also i dont really think that may solve the problem. I guess its possible the used sensor is faulty. But the thing is there is absolutely no change in how the car ran before or after whichever sensor i use. Any mechanics here work for toyota or lexus have experience with something like this. I am now responsible for the car since it had no problems running till i touched it and its sitting in my garage at home. So every day i get off work in working again in my garage till i fix this which is really stressful. |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
My suggestion is to bring it in to Toyota and see what they have to say.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
From my experience the dealership has little diagnostic experience. Thier approach to repair is to replace all sensors or components that could be possible causes of the problem. I dont need to go to the dealer for that. Otherwise i woudl jsut change the TPS IAC and VAF sensors and be done with it.
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Idle Air control valve. Take it off and clean it thoroughly. Thick carbon probably came off and got caught into the screen of the idle air control valve
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
did you probe the 'new' sensor to see if its actually sending a signal?
able to obtain a copy of a service manual? wait..wait....wait...... i-man cleaning with seafoam...first try checking the air filter....then try checking the pressure for the rail and then the injectors..... |
I think i have to agree with function. I jsut realized it the car has a very low idle which is why the car wants to die. Which will also set a code 31 the maf is functioning properly its detecting the low amount of air volume. Tomorrow i am going to remove the iac valve i bet its really gummed up. Only thing is i think i have to remove the throttle body to do that because of where the bottom screw of the valve is.
Only other thing i can think of is if the car hydrolocked and skipped timing. |
Ye Olde School..... ignoring codes and electronics for a moment (you said old ;) )
The shaky idle is normally caused by a vacuum leak. If it suddenly gets worse after something was done..... I would recheck the fuel system and hunt for the leak. Now moving to modern times...... once a code is tossed with the CEL then the ecu will revert to a base program. There are I believe 4-5 systems that "check in" with the ecu on the toyota lexus (circa 1993). If you did a top end cleaning I agree that something may have broken loose and is blocking a line. I highly doubt it was " hydrolocked and skipped timing"
some people are little slinkies. . . . .they are really good for nothing. . . .but they still bring a smile to your face when you push them down a flight of stairs. Come to the DARKSIDE..... We have candy ![]() ![]() |
#8 | |
Start another Oil Thread!
not sure if it's been said yet, but try replacing the PCV valve.. it's a 2jz.. so there's plenty of opportunity for vacuum leaks
spray starting fluid around the engine bay on vacuum hoses and if you get a sputter, you've found a leaking point.
you nailed it sir.
#9 | |
I think what im going to do tonight is remove the throttle body and clean it out and remove the idle air control valve. I am assuming its completely gummed up. I did the seafoam to try to help him out. He was getting poor gas milage. I have done atleast 50 seafoam treatments with no problems. But i guess this particular car decided to act up. From now i i dont think i will do seafoam on any car that has more than 100k miles unless its been regularly serviced and maintained for fear of causing a problem. I guess live and learn. |
just a question though... Was it working fine before you tried to "fix" it ?
If so, why did you try to fix it when there wasn't any problems? :) ok i'm not helping in any way.. |
#11 | |
do you not know what seafoam is?
you nailed it sir.
it will dissolve carbon build ups on the pistons. but why? If there's no problems with the engine in the first place, i don't see why one would do that. Now his engine is not running fine and throws a check engine...
Anyways, i made my point. thank you. :) |
#13 | ||
your attempt at sarcasm is so far a serious fail
you nailed it sir.
#14 |
hey.. my point is:
It's old, it's working. don't touch it. It's as simple as that. No offense to YarisSedan, but good luck with the car. |
#15 |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
It may be that I am just lazy (well, I am, really), but I agree with illusion: if it ain't broke, why fix it? SeaFoam has its place, but personally, I don't think that place is in a vehicle that is running fine.
#16 | |
"fine" is relative..
you nailed it sir.
#17 |
SIPNDEW
on my 93 lincoln i seafoamed and literally drove the crap out of it. all better. :)
#18 | |
clogged IAC valve?
you nailed it sir.
