Old 02-24-2009, 11:26 PM   #1
Brian
Brian's Avatar
very common toyota issue, the axle stubs stick out too far... grind them off and you should be ok.
Thanks. I wasn't sure if I should do it or not. It's not sticking out by too much. Probably about 3/16".
Old 02-25-2009, 07:12 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
yeah you should be able to use a 4" grinder on them, no problem. just use light pressure on the edges to avoid "mushrooming" the thread area. if and when you have to remove the axle, spinning the nut backwards off the stub will straighten out any minor thread imperfections.
make sure and shoot the stub with a lil paint after grinding. rust sucks :(
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
center caps for enkei rpf1s??? andruboz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-05-2010 10:37 PM
Gas Cap not tight enough? polar_white General Yaris / Vitz Discussion 6 08-14-2007 10:46 AM
center cap removal djfuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 02-23-2007 12:38 AM
Power outlet cap broke rnd243 DIY / Maintenance / Service 11 01-16-2007 09:26 PM
