Old 02-25-2009, 03:23 PM   #1
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Track Whores
All of you track whores definately need these .
http://www.pegasusautoracing.com/pro...asp?RecID=2570
Old 02-25-2009, 03:26 PM   #2
MicroHB
Drives: MY HB
oooo yes I love that website im on it everyday lol
I was considering those actually...:)
MicroHB is offline   Reply With Quote
Old 02-25-2009, 04:28 PM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Nice hardware, but it's not going to give you any more brake rotor mass, which is the real shortcoming of the Yaris brakes on a race track. Multi-piston calipers give you more clamping force and can provide better brake feel... that's not what the Yaris needs. On a fast race track, the brakes simply get too hot. Brake cooling ducts help, but some larger rotors would probably help even more.
The bling calipers by themselves aren't going to improve track braking ability one bit.
Old 02-25-2009, 04:51 PM   #4
kou
Drives: 08 lb
http://www.horsepowerfreaks.com/perf...Big_Brake_Kits
Old 02-25-2009, 09:19 PM   #5
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
They don't say whether the smallest kits will fit on 15" wheels.
Old 02-25-2009, 04:52 PM   #6
supmet
Drives: 2007 4 Door Yaris
woops
Old 02-25-2009, 05:20 PM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Loren , you must be tired . :) I hate bling :)
Everybody knows that aluminum cools faster than metal (steel)composite , not to mention the weight savings .OK the weight savings is only 2-3 lbs per caliper .
I have seen brake failures . Alot of them due to overheated calipers . Whether melting the seals and/or boiling the fluid . Keep in mind a cool pad is just as important as a cool rotor . The only way a pad can cool is through heat disapation through the calipers or with an air duct . These calipers also offer an open end design which also allow more of the rotor to be cooled . Besides , these calipers cost $50 more than a new one(reman) from Auto Zone :)
I understand that 98% of the people on this forum will never get their brakes that hot , but to the 2% that do , these are more than bling .
Old 02-25-2009, 06:30 PM   #8
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Ken , the pad # is listed on the page
Old 02-25-2009, 07:51 PM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
LOL, i meant that there are few good pads for the stock yaris caliper. sorry! yeah, i see that, so yeah, there are probably a hundred good pads for it!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-25-2009, 05:20 PM   #10
kngrsll
Apexing Egg!!
kngrsll's Avatar
mmmm.... car porn!
the big bonus to running those would be some decent pads finally. As far as i know, there are no good pads for size caliper. i am willing to bet some part number cross referencing will yield good results...
Old 02-25-2009, 10:02 PM   #11
Loren
What?
Loren's Avatar
Yeah, you never seemed like the "bling" type to me. I guess I never considered the cooling properties of the caliper itself. And pad availability is a nice plus.
IF you need to replace your calipers, anyway... I can see the advantage.
Old 02-25-2009, 10:12 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
why. stock brakes stop fine
Old 02-25-2009, 10:42 PM   #13
Loren
What?
Loren's Avatar
The do the first few times...
Then they get hot and start fading. Then they get hotter and quit working altogether! Been there, done that... fortunately, they recover quickly.
Old 02-25-2009, 11:15 PM   #14
kngrsll
Apexing Egg!!
kngrsll's Avatar
with a good high temp pad (hp+ or blue) and fluid, they should do fairly well since the car is light, but a little bit of ducting could go a long way!
loren, what kind of pads are you running now? im going to look into what other calipers may have the same part number so we can possible get another pad on the car, but i dunno what the chances of finding another are. have you done any ducting yet?
Old 02-25-2009, 11:41 PM   #15
Loren
What?
Loren's Avatar
I've got some sort of Endless high-end street pad on the car. They're better than stock pads, but they do indeed have an "End"!
Yes, some brake ducting did help.
I agree, a really good track pad, high temp fluid, and some cooling ducts should be all any of us will really need.
Old 02-26-2009, 12:02 AM   #16
kngrsll
Apexing Egg!!
kngrsll's Avatar
do you have pics of your ducting anywhere??
Old 02-25-2009, 11:53 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
5 years of racing.. i've run stock rotors (still on original rotors after 5 years) ran stock pads til 50K miles... now on project Mu pads.
never experienced brake fade
and you guys have bigger rotors and bigger calipers and bigger pads
wtf are you guys doing?
Old 02-26-2009, 12:06 AM   #18
kngrsll
Apexing Egg!!
kngrsll's Avatar
who has bigger brakes here?
Making YarisWorld Proud- Yaris at Thunderhill in Nor Cal Vanderkitten Tracking, Racing, Auto-X Forum 23 10-24-2008 10:03 PM
First track day, did not go so well. Need some suggestions Boy Blue Tracking, Racing, Auto-X Forum 25 10-23-2008 10:10 PM
Yes, I can finally post here! (Confessions of a track newbie) cleong Tracking, Racing, Auto-X Forum 12 10-20-2008 11:43 AM
Shannonville full track event hosted by BE - July/21/Sat Tiida Canada 2 07-06-2007 09:40 PM
Streets Of Willow track day - Non Yaris Warning. largeorangefont Photo-Video-Media Gallery 23 06-03-2007 08:03 PM
