Old 02-26-2009, 12:00 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
A cap as a noise filter is one thing. A cap as a solution to not having enough juice? Like I said before, if the alternator is just shy of making it on it's own power...it will work.
Now, if your alternator is consistantly working to it's max, it will only produce so much power and will eventually fail. It's like if you keep running your engine at redline...it will die soon enough.
Yes, a cap does NOT make power. It is like a battery, it stores it and releases it (albeit faster). Putting a band aid on a gushing wound is not the solution.
Yup...the photobucket pics are a smidge bigger...
― Thomas Paine
center caps for enkei rpf1s??? andruboz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-05-2010 10:37 PM
How to put center caps on wheels w/o breaking them? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-09-2009 06:29 PM
FS: Stock LB wheels, tires, caps 2K mi, NorCal JosephDoc Items for Sale by private party 1 09-20-2007 03:09 PM
Need Help on finding 15 inch Hub Caps jamal1984 Cosmetic Modifications (Exterior/Interior) 18 03-31-2007 01:12 PM
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
