Old 02-26-2009, 12:49 AM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Here are my choices if I cannot find a way to tap into the car's dimmer.
http://www.amazon.com/Universal-2-Ch.../dp/B001ES64MK
http://www.autometer.com/cat_accesso...l.aspx?vid=185
Old 02-26-2009, 01:18 AM   #2
The first one's pretty cool, 2 channels and you can mount it pretty much anywhere... Or you might get better value by using a computer fan speed controller, they run off 12V as well, and you'd get 4 channels!
Old 02-26-2009, 05:36 PM   #3
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
You can go to Radio Shack and get a variable resistor or rheostat. It is much cheaper than the autometer solution.
You can then run the the gauges lights to the rheostat, and then to direct power and adjust the lights to you liking, or run the resistor to the interior lights.
If you do it that way you can adjust the new gauges to the brightness level you want them, and then adjust ALL dash lights as a whole. Just hide the rehostat under the dash.
You can find them at Radio Shack for a few bucks.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Dome Light dimmer carlosh Central and South America 24 07-27-2007 03:37 PM
