Old 02-26-2009, 07:32 PM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Errr...no, but I am looking to find out what the speedometer error is on a stock Yaris. I don't know how ABS would factor into that, but I am interested if it does...
Cheers! M2
if you have ABS, the ECU senses speed thru an average taken from each wheel speed sensor.
generally the ABS cars are more accurate speed-wise (plastic gear in transmission can become worn/inaccurate)
and sorry, i'm no help on what the accuracy is.
crap, my post is useless
Old 02-26-2009, 07:40 PM   #2
ddongbap
God, your signature makes me laugh out loud, because according to some, YOU CANT.
Old 02-26-2009, 10:01 PM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Yes, your post is useless. Stop spreading incorrect information... Do you just make this shit up?
Do you honestly believe Toyota uses two seperate systems for measuring speed based on ABS or no ABS? Do you also believe non ABS cars have a speedometer cable running all the way to the guage cluster.
Oh, and the Yaris speedo is very accurate, provided stock sized tires are installed....
PetersRedYaris is offline   Reply With Quote
Old 02-26-2009, 10:06 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
no.
there is a gear and sensor mounted to the differential portion of of your non-abs equipped yarii transmission
in abs equipped cars the car also monitors speed from the wheel sensors. whether or not the ECU uses this information i'm not sure... most cars yes.. the yaris lol probably not
do you know what you're talking about or are you just trying to sound smart?
have you ever actually worked on a yaris or echo or scion transmission?
Old 02-26-2009, 10:34 PM   #5
PetersRedYaris
...there is a gear and sensor mounted to the differential portion of of your non-abs equipped yarii transmission
in abs equipped cars the car also monitors speed from the wheel sensors. whether or not the ECU uses this information i'm not sure... most cars yes.. the yaris lol probably not...
Now your correct... Engine ECU and ABS ECU are usually seperate systems.
...do you know what you're talking about or are you just trying to sound smart?
Funny you should say that, how do you spell hipocrite? I can't seem to remember.
Old 02-26-2009, 10:40 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
funny that you avoided my question about the C5X transmissions
i've swapped a non-abs trans into an abs equipped chassis ;) i've seen the different wiring harnesses
EGR Error, Urgent Help Needed aliraja DIY / Maintenance / Service 27 04-29-2009 07:59 AM
Changing out the stock speedometer and getting a digital daf62757 Fuel Economy Forum 2 02-20-2009 11:21 PM
Strange Error on Yarisworld last night! captainm27 General Yaris / Vitz Discussion 1 01-09-2009 12:03 PM
Error code readers (ODBII) devinlamothe DIY / Maintenance / Service 7 01-02-2009 10:48 PM
Yaris Digital Speedo Error?? jack DIY / Maintenance / Service 5 03-20-2006 05:37 AM
