#37 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
![]() It was too wierd looking for me so I went with the Beck/Arnley paper filter and got impressed, real quick!
#38 |
if K&N is sooo bad for your car then why do so many people still buy them? and are you guys really fighting over this.
come on..... really cause everyone knows that K&N is the best lol
"Igitur qui desiderat pacem, praeparet bellum." |
#39 | |
Hey, don't listen. Go spend 20 bucks on a paper filter once every 6 months or a year. I'll still have my K&N in 10. If you say K&N filters let more dirt in, you're just flat out wrong. You're arguing an invalid point. The world is flat, too, right? Come on now. It is an oiled filter. It operates on different principles, but the end result is simple. And another thing... ( ) every K&N filter you'll ever buy is going to increase the surface area of the filter element over stock. HELLO? Should I keep going?
#40 | |
http://www.knfilters.com/air_filter_testing.htm
^^ The shut up button. AND I QUOTE Quote:
#41 | |
As for the MAF, I have personally over oiled a K&N filter and caused a CEL. But cleaning the MAF is SIMPLE (using CRC MAF cleaner, don't EVER touch the element with a q-tip) and disconnecting the battery resets the light. No harm done. Compared to a stock paper filter, K&N's are better in every way... |
#42 |
Drives: yw calls me douche and racist. Join Date: Aug 2007
Since Toyota would have filters that'll damage their engines in the long run. Or maybe fine dust DOESN'T MATTER?
#43 | |
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
#44 | |
#45 |
You've never looked at one? It's not a hollow tube. Noticed the wire harness that plugs into it?
#46 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I've had great success with K&N's over the years with no MAF issues. Here's my process;
Remove K&N drop-in Re-install original OEM filter (which was nearly new when initially removed) Remove any litter (bugs etc) from the dirty side with a soft brush. Using K&N cleaner from kit, thoughtly soak and back-flush the K&N filter with warm tap water. Shake off excess water and air dry overnight. Next day (when 100% dry), spray both sides liberally with K&N filter oil ensuring that all pleats are moistened. Lay filter on paper towelling for a couple hours to drain any surplus oil. Wipe excess oil from filter frame and re-install in stock airbox. The K&N service kit suggests cleaning be done at 50,000 to 100,000 mile intervals (for on-road use). I do so annually which is approximately 25,000 kilometers (~15,500 miles) I recently cleaned the filter after 27,000 kl. in my Yaris Sedan. It was much cleaner that past K&N's I've used which were cone types on K&N intake systems (Turbo-Talon, 5.0 Mustang). Could be that 1.5 hp doesn't draw the same volume of air as 200+ hp plus the Yaris filter has been protected inside the airbox with dirt only being drawn in from the bottom, whereas the cone filter are exposed to all dirt flying about the engine compartment, not just that pulled up to it by engine vacuum.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#47 | ||
#48 | |
![]() Sounds like you pulled the trigger on a K&N filter since the 24th!
#49 |
Pop quiz: What element of the Yaris's MAF could POSSIBLY get dirty enough to cause issues?
A: The mirror! Yarii have a Karman Vortex-style MAF. It works via a mirror located in the stalk of the sensor. Air is redirected up the stalk and against a tiny little mirror, and the oscillations of that mirror are measured via a photoreceiver that receives LED light that is reflected off the mirror. SO, you guys are telling me that oil from a filter is going to make it all the way up the stalk of the MAF, contaminate it, and then the filter is going to let in enough dirt (which is also magically going to take a trip up the stalk of the sensor) and ruin it, too? No, it won't. That is why Toyota uses these MAF's and have for decades. They are reliable. That is to say nothing of the fact that properly installed oiled filters do nothing to air flow sensors in the first place. You guys are arguing urban legend. It comes up here about once a year, and it gets shot down every single time. |
#50 |
:insert beating the dead horse .gif here:
#51 |
Poor design. MAF circuit boards are sealed w/ silicon, and they are connected directly to the underlying hardware. Engine heat and general wear and tear can cause the plastics of a MAF sensor to degrade and allow some of that silicon to coat the thermistors and other good bits. This is usually the cause of "dirty" sensors... it actually comes from the sensor itself.
#52 | |
Thanks. I'll look for one of those at the next StarTrek convention. ![]() I just pulled mine out, it's not as fangled as you make it sound. Look at it. Airflow is directed straight up into the sensor, across the 2 wires that MEASURE the AIRFLOW, passes on thru the sensor and down into the main airflow to the throttle body. And the main thing that needs to be remembered is that it's not downstream a foot or two, it sits directly above the filter, mounted right on the airbox. |
#53 |
Its the simplest air flow meter that I know of.
#54 | |
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 105 | 06-20-2019 12:59 PM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| Cold Air intake with k&n filter | _S7V7N_ | Performance Modifications | 23 | 12-19-2008 02:36 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| K&N 57i filter for TS 1.8 | jim TS | Performance Modifications | 5 | 06-24-2007 05:00 PM |
