Old 02-26-2009, 08:41 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
couple problems with front upper
yaris has socket head inside the top of the strut rod
echo(and most other struts that have a 3bolt mount) has flatsided portions that the spring top hat fits into to keep it from rotating. also the bearing surfaces are different between the two shocks. the yaris upper mounts would bind up if used with echo shocks
how much "off" are the lower bolt holes between the echo and yaris?
next question...
why are we sticking to toyota here? anyone thought about maybe a mazda strut?
yea, i had not thought of that. i figured i could just swap the upper mount on and it would not be a big deal. The echo shocks dont have a flatside on the strut though, so perhaps that wont be an issue.
i just found out that echo shocks fit xA and xB, i was not aware of that...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-26-2009, 08:56 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
yes they do!
back to other questions.. are there any other cars that utilize top 1bolt setups?
VW golf !
Golf III that is ( 1994 or so)
Old 02-26-2009, 09:13 PM   #3
kngrsll
Apexing Egg!!
kngrsll's Avatar
yes they do!
VW golf !
never thought of that... what makes you think the lower mount will work? is there some sort of universal size i dont know about??
Old 02-26-2009, 09:26 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
nothign makes me think it will work. but there will be 100X more options for a golfIII than a toyota echo (that's not 1bolt upper anyway)
modification is modification
and since a golfIII is heavier than a yaris, you'll be starting out with stiffer valving to begin with. which is FTW
Old 02-26-2009, 09:36 PM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
ok, i see your point... want to buy some koni's? LOL
Old 02-26-2009, 09:39 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
i bet if you call tire rack they'd be kind enough to give you dimensions of the lower bolt holes c/c for the golfIII
also it looks like the yaris "leans" more (bolt holes)
if you get the shocks i'm willing to weld/modify the brackets to fit a yaris.
Old 02-26-2009, 09:45 PM   #7
kngrsll
Apexing Egg!!
kngrsll's Avatar
awesome, thats really nice of you... i will do some more research and get back to you. id rather figure out how to get these konis on though since i already have them.
LF: Yaris / Vitz / Echo hatch accessories / parts! Keej_05RS General Yaris / Vitz Discussion 3 12-08-2008 09:43 PM
Confused...vitz, yaris iLikeVitz General Yaris / Vitz Discussion 10 07-24-2006 03:24 PM
