![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Thats backwards ,,the higher octane burns cooler than lower octane thus the carbon builds up ultimately choking your engine and oil with carbon and sludge build up.You might want to check your timing for that rattling you are hearing as the car should run smooth and quiet on regular octane gas.
#2 | |
higher octane fuel is less likely to detonate prematurely. this means it doesn't burn when it should without a timing/spark advance. without a way to advance timing, higher octane fuel will cause your engine to run a little hotter (ever run a briggs and stratton on 93 octane? after awhile you'll notice the header will be glowing red hot)
Been a long time messing with cars.. Last edited by Tamago; 02-27-2009 at 08:21 AM. |
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2008
I can believe this, but going form 87 to 89 would wreck a motor? Using race gas, yes, using +2, though?
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| Economics of Price Gouging and Gas shortages | GeneW | General Yaris / Vitz Discussion | 1 | 10-31-2008 04:20 PM |
| A question about the gas thingee -- the place where you stick the nozzle. | petesimac | General Yaris / Vitz Discussion | 11 | 07-18-2007 08:23 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
