Old 02-27-2009, 07:13 AM   #1
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by jambo101 View Post
Thats backwards ,,the higher octane burns cooler than lower octane thus the carbon builds up ultimately choking your engine and oil with carbon and sludge build up.You might want to check your timing for that rattling you are hearing as the car should run smooth and quiet on regular octane gas.
actually no.
higher octane fuel is less likely to detonate prematurely. this means it doesn't burn when it should without a timing/spark advance.
without a way to advance timing, higher octane fuel will cause your engine to run a little hotter (ever run a briggs and stratton on 93 octane? after awhile you'll notice the header will be glowing red hot)
Old 02-28-2009, 10:25 AM   #2
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
I can believe this, but going form 87 to 89 would wreck a motor? Using race gas, yes, using +2, though?
Tonavi is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 04:20 PM
Gas question Meldav86 General Yaris / Vitz Discussion 23 09-28-2007 06:52 PM
A question about the gas thingee -- the place where you stick the nozzle. petesimac General Yaris / Vitz Discussion 11 07-18-2007 08:23 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
