![]() ![]() Drives: yaris advance Join Date: Jan 2009
MORE PICKS
thank you for your comments, here are more picks, the first thing I did not like was the fact that theres not really foot rest, and since I wear boots most of the time the rubber cover of the pedals can get slippery when wet, so I found this aluminum pedals, for just $ 6.00, and I cut a fitted the alluminum diamond plate that I got from work, with the screws that I did not used from the pedals, so itīs a lot better for me, specially if you like the industrial look
P1310086.jpg P1310086 (2)_editado-1.jpg I also made the pioneer HU fit in this place, and since it got usb input, I put it on the side pocket, with the auxiliar cable and other audio cables that I could use,even if want to use the cell phone. P1310090 (2).jpg P1310110.jpg Even with 5.25 2 ways JBLīs in front, I did not like the from image, so I install the eye-ball adjustable Power Acoustic in the pilar, and they do make a great different, very happy with there performance, and combine with the rear super tweeter of the Pioneer 6x9, I can pump the volumen with no problem, not to mention the high pass in the radio with different frecuncy set up ![]() P1310114.jpg I looked for a stailess tip for the muffler and found this one, that like every thing else i cut and modify to fit to an angle that match the actual tip, and it looks great. P1310109.jpg P1310108.jpg Iīm shure you like the Toyota logo P1310107.jpg Well I hope this will give you more simple ideas of what you can do with out using a pro... |
