![]() ![]() Drives: '08 Yaris LB Join Date: Oct 2008
Been there. Baking the headlights is easy (250 degrees in the oven for about 10 minutes). They actually come apart easier than the stock ones. As for the LED's, if you are referring to the halo ones, you don't need to bake the headlights to get those out. Just take the outer wiring apart from the housing and you will see that the halo LED's are easy to pull out. Once you have them out, go to Radio Shack and pick up a set of replacement LED's. They have them in all colors. Match the size as best you can and solder the new LED's in place of the old ones. It's a bit tricky at first, but with some patience it's not hard at all. I jerry-rigged a flashlight to test the new LED's to make sure I knew + and -. As for the 3 upper LED's in each light, those are a different story since they are a completely different LED set-up. I checked everywhere on eBay to get replacements and they are damn near impossible to locate.
I used to have 1700 posts
damn near impossible, does that mean you did not find them or u found them but it took a lot of searching?
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 09:10 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| LEDs to replace interior lights: Which ones? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 57 | 04-28-2010 01:44 PM |
| Gentex K31 - auto dimming mirror w/ map lights, compass, outside temp. -- installed. | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 22 | 01-06-2009 07:34 AM |
| GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... | riceboy | Items for Sale by private party | 453 | 07-14-2007 08:30 AM |
