Old 02-27-2009, 10:29 PM   #1
ToddR
Bacon!
ToddR's Avatar
Drives: 2008 Red Yaris LB
Originally Posted by supmet View Post
How can I tell if my tint has metal in it? I just asked for limo in the back, and one step lighter than limo in the front at a stereo/tint shop.
http://www.tintcenter.com/articles/bt_types.html
You could probably call the shop that did the work and ask them.
I think the TMPS data goes to a separate computer, so the Scanguage might not have access to the data. I can't tell from the manuals that I have. Maybe somebody else here knows.
ToddR is offline   Reply With Quote
Old 02-28-2009, 01:17 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you are correct.
Old 02-28-2009, 01:18 AM   #3
silver_echo
ekodrvr
silver_echo's Avatar
from what i understand, the easiest way to do it would be to take out the original sensors out, and put in a new set that was purchased specifically with the gauges... one downside to think of, the reason that a lot of tire shops have a disclaimer that states that it must be changed every time is because there are a lot of techs in the field who "forget" to check for TPMS and break the sensors... if that happens, they will replace it with a factory sensor and you will be lucky if they tell you that they did it...
silver_echo is offline   Reply With Quote
Old 02-28-2009, 01:22 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
yeah, i already mentioned this to the OP
and it sounds like you should go to a different tire shop there in spokane. the discount tire in the valley was FTW back in the day
where in spokane are you?
Old 02-28-2009, 01:43 AM   #5
silver_echo
ekodrvr
i am spokane valley, currently at SCC in the auto tech program... there are people in the classes from pretty much ALL the major shops here, and they are all saying that it is an issue at the shops in town... luckily my car does not have or need the TPMS sensor because it is old enough to not require it... i usually shop at discount in the valley, because they usually try to treat me right... but i usually don't worry about tire pressure too much because somehow, i have been able to tell when i am low on pressure(even by only about 5 lbs.)... so do you remember the les schwab commercials of "we come running when you stop in"? <----- tell me another one... they don't even try!... so when did you leave spokane and why?
Old 02-28-2009, 01:44 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
i am spokane valley, currently at SCC in the auto tech program... there are people in the classes from pretty much ALL the major shops here, and they are all saying that it is an issue at the shops in town... luckily my car does not have or need the TPMS sensor because it is old enough to not require it... i usually shop at discount in the valley, because they usually try to treat me right... but i usually don't worry about tire pressure too much because somehow, i have been able to tell when i am low on pressure(even by only about 5 lbs.)... so do you remember the les schwab commercials of "we come running when you stop in"? <----- :rofl: tell me another one... they don't even try!... so when did you leave spokane and why?
graduated from FLPT program at SCC in 2001
i'd been in spokane since 1998, moved to seattle after graduation and then moved to fl 2 years later. . .
Old 02-28-2009, 01:54 AM   #7
silver_echo
ekodrvr
FLPT? what is that? never heard of it... so yeah while on the subject of SCC, the bowling classes have been cancelled and the alley may be coming out of the campus after last week... some instructor did not listen to the maintenance person who maintains the alley and got himself killed...
Old 02-28-2009, 02:22 AM   #8
Tamago
Tamago's Avatar
Drives: UZJ100
wow no way!
FLPT = fluid power. same building as you i believe (or diesel mechanics, i don't remember) and the machine shop is there too
Current draw on battery, possibly glowshift gauges? goku87 In Car Entertainment + Electronics (audio / video / alarm) 49 09-12-2009 10:21 AM
15" TPMS friendly wheels for my '08. Ideas? auxmike Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 12-08-2008 08:01 PM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 03:57 PM
FS: Brand New TRD Gauges Cluster cm07yaris Items for Sale by private party 9 09-27-2007 02:26 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
