Learn to Relax
Thanks for sharing!
I hope people appreciate your efforts to share your experiences.
It looks like you're near Dole Cannery?
#2 | |
It was ran in 3rd gear. It wasn't ran to redline because I wasn't sure where redline was. I told him 6100rpm to be safe. When viewing all of the dyno charts on the dyno thread, everyone peaks right at 6k or a little before, i see none of them peaking higher than 6k. Also the guy doing the dyno said it doesn't really matter which gear it is in with a dynapack, but moreso with a dynojet. However, he usually pulls cars in 4th gear if they have an aftermarket ECU. I ran 87 because the blitz s/c purchase was an unexpected purchase. If i knew far in advance that I was getting this kit, I would have circulated 92 many times before the dyno run. This low number is fine. I will be returning to the same dyno and telling them to rev it to 6300rpm next time? I will have the blitz s/c, headers, 92 or 91 octane with some lucas mixed in there, an NST lite pulley, ngk iridium tip 7 heat spark plugs, and either a cat back/nitto midpipe/ or custom exhaust setup running 2.25" piping. Either way, i will know my current HP numbers at that time, and that's all that matters. And I KNOWWWW i'll break atleast 90whp! hah Last edited by PETERPOOP; 03-01-2009 at 01:20 AM. |
| TS/Xd Long Tube Header & Intake dyno results | richardholdener | Yaris TS Talk | 21 | 01-06-2009 05:28 AM |
| NST Pulley Dyno Results | richardholdener | Performance Modifications | 51 | 12-18-2008 09:11 PM |
| Long Tube Header Dyno results & Photo | richardholdener | Performance Modifications | 59 | 11-26-2008 05:27 PM |
| dyno results are in!!!! | turboyaris | Performance Modifications | 105 | 04-01-2007 06:03 PM |
| WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! | WRLEO | Sponsors Classifieds Area | 0 | 02-22-2007 10:14 AM |
