If you swap hu and hl then high and low functionality will be reversed. Did the new stalk replace the existing and the factory connector plugged back in?
![]() ![]() ![]() ![]() Drives: 2007 Toyota Yaris Blazing Blue Join Date: May 2007
![]() ![]() Drives: 2009 Yaris LE 5 dr Join Date: Feb 2009
Can you tell me how much the new stalk was please?
Installed the fogs myself. From the fogs there is a ground wire which I grounded by the driver side headlight, and another wire that I wired into the plug in the fuse box under the hood. Plugged the Toyota relay under the dash. Then installed the stalk and plugged in the harness.
#7 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Rear fog light for US '08 3Door Yaris (stick shift9 | Stefan | DIY / Maintenance / Service | 21 | 04-21-2010 04:30 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
