Old 03-06-2009, 08:55 AM   #1
ToddR
Bacon!
ToddR's Avatar
Drives: 2008 Red Yaris LB
FYI
Running the heat on the "Defrost" setting will run the A/C compressor to remove moisture from the heated air. This will cause the same drop in fuel economy as running the A/C to cool the car. If you do a search here you will find a more detailed explanation.
ToddR is offline
Old 03-06-2009, 04:40 PM   #2
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
Originally Posted by ToddR View Post
FYI
I don't think so. You have to punch the A/C button to do that.
NJBob is offline
Old 03-06-2009, 04:47 PM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
No, you don't, and that's the whole gripe that everyone has with it. Whether or not you have the a/c button depressed, if you use either of the dedicated defrost settings the a/c will run along with the heater, simply for the dehumidifying effect.
- Brian
Share the Road
BailOut is offline
Old 03-06-2009, 05:29 PM   #4
NJBob
NJBob's Avatar
Red face
My bad...I guess. I can't find anything in the owner's manual but when I have the settings on defrost I can hit the A/C button and feel the compressor turn on. When I hit it again, it, of course turns off.
I'll have to see but I understand what you're saying. My Neon had the constant A/C to defrost which worked great but wasn't always necessary to clear the windows...not to mention it bumping up the rpm's and burning more fuel as consequence.
NJBob is offline
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 11:22 AM
PTC heater in 2009? twowheels DIY / Maintenance / Service 3 02-02-2009 10:41 AM
Rostra seat heater and lumbar support sesmith In Car Entertainment + Electronics (audio / video / alarm) 1 01-03-2009 08:51 AM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Rattling Noise with A/C Fan? Sabretooth DIY / Maintenance / Service 16 05-15-2007 03:27 AM
