Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Yes, using the heater and fan does use more fuel. The hit is not nearly as large as with a/c but it is there.
The fan requires electricity and the alternator puts more of a load on the engine to produce it. The engine also produces only so much waste heat that makes it into the cooling system, and it often experiences drops in the coolant temperature which causes the ECU to cause the engine to burn more fuel (by running richer and/or at a higher RPM). This means that sometimes you're pulling heat from the system that the engine cannot afford to lose, but other times it is happy to dump excess heat. Sometimes you simply need to use the heat. One should never allow themselves to get too cold in the car. However, like any other use of energy it is best kept to a minimum. Wear a coat and hat and gloves and you'll find you don't need to use the heat nearly as often.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
![]() ![]() ![]() ![]() Drives: Yaris 5 door liftback Join Date: Jan 2009
#3 | |
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
![]() Now back to being positive!
#4 | |
The Dodge Calibre does it too, that's one I know of for sure.
- The Black Ship Yaris - |
#5 | |
![]() Drives: yaris Join Date: Dec 2008
The fan takes up close to zero power, especially at the low settings. It's insignificant compared to the headlights, much less the A/C. |
| engine block heater | linny | DIY / Maintenance / Service | 6 | 01-19-2012 11:22 AM |
| PTC heater in 2009? | twowheels | DIY / Maintenance / Service | 3 | 02-02-2009 10:41 AM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Rattling Noise with A/C Fan? | Sabretooth | DIY / Maintenance / Service | 16 | 05-15-2007 03:27 AM |
