View Poll Results: Should I get the SSK to make the clutch more user friendly?
Absolutely worth the expense, makes a big difference 14 46.67%
No, you'll get used to stock clutch, not worth it 11 36.67%
No, it will void your warranty 2 6.67%
What's a clutch? 4 13.33%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Old 03-06-2009, 09:50 PM   #1
tomato
tomato's Avatar
As cali very correctly pointed out, the SSK has nothing to do with the clutch.
My bad. I don't know any better. To be honest, most of the terminology I see on this forum is completely new to me.... so sorry if I said something stupid, here!
I meant the whole shifting process is stiff, counter-intuitive (especially in low gears - the first is the worse! - and in reverse) and I want to figure out a way to get over that hurdle sooner rather than later
I looked stuff up online, and if I understand your answers correctly, it seems that my problem is with the shifter mostly. Looks like I'm getting used to the clutch by now.
But I wonder if someone could explain (in simple words, please, I'm no mechanic!!! ) how the SSK makes it better.
Thanks
Old 03-07-2009, 02:37 AM   #2
Thanks
From the sound of it, you found the trick to the clutch: give a lil more gas than usual when shifting, and release the clutch pedal gently (especially from a stop). So that covers your footwork.
The SSK's and other transmission mods affect your armwork: You'll have to push the gear lever a shorter distance to change gears (so you can change them faster), and the lever will feel much more solid and direct with the various bushings. It's hard to explain in words, but these basically help you shift faster and with a better feeling.
Old 03-07-2009, 03:39 AM   #3
NonStopTuning
Thanks
The following thread would be a good place to read tons of user reviews and comments regarding the NST SSK options...
http://www.yarisworld.com/forums/sho...&highlight=nst
Good luck and have fun with your project!
MIKE @ NST
www.NonStopTuning.com
Manual shifter Mod.... hoahmaru Cosmetic Modifications (Exterior/Interior) 28 04-07-2014 05:05 PM
Manual Transmission...Safety Issue!!! twocvforme General Yaris / Vitz Discussion 189 10-30-2010 11:00 PM
Manual Transmission woes thatboyjer General Yaris / Vitz Discussion 24 07-30-2007 07:46 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
JDM Center Console Box + Manual Transmission bigsky2 Cosmetic Modifications (Exterior/Interior) 5 11-28-2006 08:08 AM
