Old 03-10-2009, 10:45 AM   #24
Yaris-x
Yaris-x's Avatar
Drives: 2008 Yaris HB
FYI 175, 185, 195, 0r 215 all have the same outer Diameter That is the width of the tire in snow you want narrow tires I run 175 in the winter and I pass 4x4 suv's all day I live in Syracuse NY the snow belt of the world. so 175 = 175mm of width 65 is the tire height so 65 = 65% of 175 and R14 obviously is the rim size
In snow wide tires are bad the wider the tire the bigger contact patch and the weight of the vehicle is spread over a larger area and the car is more likely to float on the snow causing a more unstable ride (My wifes xA is on 195 tires and I learned the hard way her car is horrible in snow) with narrow tires the car's weight is focused on a smaller area and the car is more likely to cut threw the snow.
Yaris-x is offline   Reply With Quote
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 11:08 AM
FREE GROUND SHIPPING TO YARISWORLD MEMBERS zetaproducts.net ZetaProducts.Net 10 12-05-2008 09:29 AM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Can you purchase the Ground Effects for S Sedan? formerechoowner Cosmetic Modifications (Exterior/Interior) 1 04-18-2007 10:15 PM
