![]() Drives: yaris sedan 2007 Join Date: Oct 2008
amp under the driver seat
I just want to share my diy project. I am not an expert with car audio, i just learn almost everything in this forum. thanks to everyone who always share their diys, thats a great help. heres some pix:
Y4R1Z
WOW! That is a damn good looking install... my amp is just sitting under the pass seat with wires everywhere. I've been wanting to properly mount it and clean up the look and keep it from bouncing around, but I've been procrastinating for about a year now. I really like what you did, it inspires me!
yap. very good install.
but note: i think the fuse should be as close as possible to the battery. |
tnx for that guys.. actually i have a fuse near the battery. that one besides the amp is like a sort of circuit breaker similar to what we are using at home. coz am afraid i might blew up the whole thing so i install that one. and if i want to add another amp or if i need to power something i've got one slot ready...
Hack.... What hack ??
That's a great install jeftwithatee.
Thanks for posting the pics and welcome to the forums. Hope you didn't do that install with a few dark & stormy's under your belt
Audio Junky
good job on the fuses. My only concern is that you might want to go with a lower rated fuse. I couldn't tell if that was 4awg or 8awg you had going to the amp on that distroblock/breaker.
It looks like 8awg in & out. In which case a 30amp fuse/breaker would be much safer. If you had 4 awg in, and then 4awg out... 60amp is fine If you are using 8awg at all, in or out, that might be unsafe to have the fuse/breaker set at 60. There are calculators to find out for sure if it is safe or not. Just google a site called Basic Car audio and Electronics. and search for the calculator, under the wire or fuses tab. Everytime you reduce the size of the wire you should always re-fuse. Nice looking install. |
'09 5dr
Drives: 2009 Yaris 5-Door Bayou Blue Join Date: Oct 2008
WOW!! Amazing installation! Good job!
2009 5-Door Yaris LB Bayou Blue Pearl 2009 5-Door Yaris LB Black Sand Pearl |
It looks great. You might want to put some tape or a cap on The positive and negitive terminals just in case a coin or metal pen or object should fall on these and cause a short
tnx very much for the comments guys.. i will considered that talnlnky... its a very good advice actually.. i didnt know about that.... its good you giving comments so i can correct my mistake.. tnx again i appreciate it..
boydstir
i did two arc audio amps under the seats here is my pics just for kicks
[IMG] [/IMG]
Y4R1Z
nice... are those both for speakers? or is one for subs?
boydstir
one for each and i changed one of them to a 1000X1 sub amp instead of a 600X1 sub amp all arc audio componets the sytem rocks thats for sure
[IMG] [/IMG]
#14 | |
-- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
#15 |
boydstir
#16 |
and Then mine after his
#17 |
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Here is another example.....
#18 |
╚══════════RN
Wow. You fit two amps under one seat?
| Driver seat | TEHxFALLEN V1.2 | General Yaris / Vitz Discussion | 4 | 01-21-2018 04:29 PM |
| Amp fit under driver seat | dlinkwit27 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 10-18-2010 09:14 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Rostra seat heater and lumbar support | sesmith | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 01-03-2009 08:51 AM |
| Amp install under the passenger seat questions.. | MudBug | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 06-06-2007 11:12 AM |
