Old 03-10-2009, 10:17 PM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Back on track here, the P/N for the relay is: 90987-02012...
cm07yaris is offline   Reply With Quote
Old 03-10-2009, 10:43 PM   #2
That part number is listed for many other cars for various purposes, but not for the Yaris. The Yaris fog light relay part number is 90987-02027.
I am not sure what the difference is between the two, but I would check both with an ohm meter to see how they compare.
Looking at the bottom of the relay the terminals are arranged like this:
1 2
5-
3-
On the correct fog light relay:
1 to 2 is the coil and should read somewhere around 100ohms
3 to 5 are the contacts and should be open
1 to 3 and 1 to 5 should be open
2 to 3 and 2 to 5 should also be open
Old 03-23-2009, 06:02 PM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
I bought this relay a loooong time ago when the other thread was still around (with the DIY fog lights OEM style).
Was the relay the issue? If so, I will order the correct PN. For reference, I have the Denso relay 90987-02012.
devinlamothe is offline   Reply With Quote
Old 03-23-2009, 07:16 PM   #4
cm07yaris
I have tried 3-5 different relays, so I'm pretty sure it isn't a relay issue. Still trying to get to the bottom of it.
Old 03-28-2009, 10:19 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
here is a picture of the relay circuit
check it agaist your relay's
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 04:30 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
