Old 09-26-2006, 04:19 AM   #1
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
Basically, there's two ways to work a headlight, switched positive, in which the switch exsists between the positive side of the power and the headlight. In a switched ground system, the switch lies between the negative side and the bulb... I'm not sure why it makes a difference, but apparently it does.
paultyler_82 is offline   Reply With Quote
