Old 03-13-2009, 09:31 PM   #1
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
actually delrin is machined, urethane is the only one needing a mold... there is just some care needed in machining the delrin as too much heat in the piece will cause it to thermally expand or the plastic will melt to the cutter... I will keep you all updated on the process.
turboyaris is offline   Reply With Quote
DIY - NST shifter bushings kurokoma-kun DIY / Maintenance / Service 1 04-05-2009 08:31 AM
NST Shifter Bushing Kit ruimond Performance Modifications 5 12-06-2008 12:48 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Aftermarket Short Shifter UPDATES ChinoCharles Performance Modifications 40 05-23-2007 03:17 AM
