Old 03-16-2009, 12:39 AM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
radio is a radio
works the same way
even if it was its not noticeable even the least bit
maybe its because we live in big sprawling cities
not all radios are created equal...some work better than others.
Also, to broadcast it on a forum and make it sound as though there are NO ill-effects is a disservice... You've got at least one person on this board who appears to have tried it... and got the shaft.
At the very least you should be kind enough to fellow yarisworldians (???) and say, "Hey, this technically degrades your reception, so... you might screw the pooch on this one if you already have a weak reception".
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Quality Shorty Antenna HB fazali Cosmetic Modifications (Exterior/Interior) 11 09-14-2007 11:53 AM
LEXUS RX330 ANTENNA MOD ROCKLAND TOYOTA Cosmetic Modifications (Exterior/Interior) 29 07-29-2007 03:09 PM
