![]() ![]() Drives: 2010 LB Meteor Metallic Join Date: May 2006
Yaris Squealing Sound
With your stereo off, has anyone else noticed that within 3 or 4 feet from a cold take-off that your Yaris makes a high pitch brief squeal similar to the sound a running shoe makes on a basketball court?
The dealership said that they couldn't figure out where the sound is coming from and when they started up 3 other Yarises for comparison they heard the squeal from them also.
![]() ![]() ![]() ![]() Drives: Absolutely Red Liftback Join Date: Aug 2006
Thats why you're supposed to wait till the cool light goes off
#3 | |
![]() ![]() ![]() Drives: two yaris liftbacks Join Date: Jan 2006
Mine doesn't do it. You should go back to the dealership and demand a good answer to what the noise is.
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Most likely a loose or glazed altenator belt.
The early bird gets the worm, but the second mouse gets the cheese. |
Mine doesn't do that either.
#7 | |
![]() ![]() Drives: Barcelona Red 5spd sedan Join Date: May 2006
then let her rip! |
#8 | |
MANUAL!!!! WE DON'T NEED NO STINKY MANUAL
![]() ![]() Drives: Yaris Liftback 3dr (Silver) Join Date: Sep 2006
I had the same problem!! From a cold start, it would squeal. And once I added more gas, it would go away. Then as time went by, it would make that noise when I braked or clutch. Turns out it's some belt that needs to be tighted. It was literally a 5 min fix.
It was so embarassing driving around and have it screech like that.
07 Yaris LB 3dr Silver Mica 5sp manual shift |
#10 | |
HardlyDangerous
Yeah if you want the best mileage a car gets 0 mpg while idling and a cold engine uses a lot of fuel until it warms up. Driving seconds after you start your car will give you the best mileage. The question is... Is it good for the engine? Toyota and every car mfg is in the business of selling cars, PERIOD. They don't care if you wear out your engine in 100,000 miles, fact is they want you to buy more cars. They do however need to make them reliable enough that you don't have major break downs so you will buy more cars from them. Warming up a cold engine hurts fuel mileage and may shorten the life of the emmisions componts slightly but it's good for the engine. Even 30 seconds to a minute will extend the life of your engine by allowing the engine to warm up slowly and not under load. The steel cylinders and aluminum pistons expand at much different rates and operating an engine under load before it has warmed up and allowed the cylinders to expand an bit shortens the life if the cylinders, rings and pistons. For the people that can't afford an extra minute in cold weather should start using Amsoil 0W-30 to prevent cold start and operating below normal operating temp engine damage. I've always let all my engines warm up even if it's only a minute or two usually never longer then 3 minutes.. I build and rebuild engines for a living, and can tell you it's easy to see the difference between and engine that was allowed to warm up and one that was driven cold. just like it's easy to see the difference between and engine that used synthetic or conventional oils.
Small Car Lover
^^^That's some really good insight. I knew that you should ease in driving when the car is cold. I sometimes especially when it gets colder let the car go for awhile but when I go to work in the morning I just drive off BUT I take it easy until it warms up or at least when the blue light is off, is that okay or does that shorten the life of the cylinders as bad as just driving off "normal" or aggressively?
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will. |
I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
I have the same problem too, but what I heard is not a squeak, but something like some gas being release from a valve... but it just happened once in every start up, not during the drive.
#13 | |
HardlyDangerous
Right now with the current temps it's not so bad. Coolant temps cold are still 40 oF or higher. It does not take too long for the engine to warm up, and if you can drive it real easy for the first couple mintes you should be ok. But when the temps drops way down like it does in the winter up here in Canada and the norther US driving off with sub zero coolant temps will not allow the cylinders to expand nearly as quickly as the pistons. Not only does it take 2X longer for the coolant to warm up but the metals have shrunk even more due to the cold. Aluminum pistons expand at a faster rate then steel cylinders so the longer you can let it warm up the better. If you don't what happens is the aluminum pistons expand quickly (under load) and you get what is called 4 point scoring or in the worst case cold sieze the engine. Because pistons are often cam ground (out of round when cold) or thicker in the areas around the wrist pin boss they expand in different areas faster and these point will contact the cylinder walls scoring it. And after a while you start to lose compression due to the cylinder and ring wear. Also it depends on where you live for instance 500 feet" from the end of my driveway is a busy road with a series of stop and go at stop signs and lights. That kind of driving on a cold engine is not good. At my old house I lived right on the highway and had to be up to 80km within' seconds. So in my case I let my car warm up for 30 seconds to a minute before I drive off in the summer and in the winter I'll give it 2 minutes or so and then still drive it easy for the first 5 minutes. Now if I lived in an area where I could get on the street and drive it easy for a mile with out needing to accelerate from stops or keeping up with traffic I would not be so worried about letting the engine warm up more. But as i said driving it easy for at least 5 minutes is a good idea before driving it normal or aggresive
#14 |
HardlyDangerous
BTW
I find every time I use the E-brake to slide into a parking spot or to do a U turn, or drift around a tight turn I get a loud squealing from my car but in my case it's usually coming from the passnger seating areas but only if I have passengers in the car. The fix to stop the squealing was easy, leave the wife at home
#15 |
![]() ![]() Drives: 07 Yaris LB, 06 VW GTI, 06 G6 Join Date: Aug 2006
No problem on my LB yet. 5800 Miles. Auto tranny.
#16 |
Small Car Lover
Thanks 07WYarisRS for you help.
I fourtantly live in a neighborhood with slow residential speed limits so until I get to the main streets, but they are 40mph and 50mph respectively and I'm not far from the highway but I have to go through some what of a maze to get to that so that helps with warming the car before gunning it. On a side note: You probably already know this and I'm not trying to preach, but using your hand-brake the way you discribed it wears out the teeth-I think that's what it is, anyway its not good for it, at least excessively, but I know its fun, I've done it plenty of times but I restrain myself.
#17 | |
#18 |
boydstir
i have a chattering noise on the belt side of the motor its cycles like a ac clutch but maybe its the idler pully or altenator cant tell only does it in the morning when it starts up till it gets warm then it seems to go away i did tighten the belt that helped from the sqealing that happend some times for only 5 seconds or so each time no belt sqeal but the chatter is still there i have 68000 miles on my yaris lb
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 09:18 PM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
