Old 03-17-2009, 08:09 PM   #1
ricktoyota73
ricktoyota73's Avatar
Drives: 2014 Yaris 3-Door
Just curious, if I'm not putting in a switch and don't care if I ever enable the system again, can I just cut and connect the wires to the resistor package instead of using tap splices?
ricktoyota73 is offline   Reply With Quote
Old 03-17-2009, 08:24 PM   #2
Yes you can.
I wrote it up with use of the tap splices keeping in mind that many people are not comfortable soldering under the dash (and in relatively close proximity to the passenger air bag).
Old 03-17-2009, 09:15 PM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
thats what i did and it works fine, i even removed both TPMS modules, one under the dash and one in the paneling behind the trunk. theres a good .02 lbs and weight saved!
mikenacarato is offline   Reply With Quote
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
