More than likely the contact inside the dome light housing is bent. You could try bending the tabs a bit and see if it works again. If not just place the whole dome assembly. Maybe 30 bucks for a used one. If you know how to use a multi-meter. Check the voltage at the terminals the dome light connects to and having someone open and close the door. See if the voltage is always constant when door is open like it should be.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| 12 LED Dome Light Festoon | bigsky2 | Cosmetic Modifications (Exterior/Interior) | 26 | 04-18-2010 11:38 AM |
| Trouble putting 3rd brake light after rear speaker install..... | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 12-05-2008 04:10 AM |
| Dome light dimm | slvryaris | DIY / Maintenance / Service | 3 | 12-02-2008 09:06 AM |
| Festoon (dome light) led bulb fit?? | ||)) (o) ||\|| | Cosmetic Modifications (Exterior/Interior) | 5 | 03-22-2007 03:22 PM |
