Old 03-18-2009, 09:47 AM   #1
Iggy888
Iggy888's Avatar
Drives: 2008 5 Door Liftback
Originally Posted by andru47 View Post
Same interface, but scrolling is a lot slower, at least on mine don't know about the x100
There are youtube videos just look it up so you can see how it works. Ida-x200 or Ida-x100
As you would expect from looking at it, the big wheel in the middle of the iDA-X100/iDA-X200 allows you navigate the content on your iPod in a manner similar to using your iPod.
Because it connects via USB, songs load almost instantly.
To speed up the process of searching through large music collections, you push in on the big wheel first and then rotate it left or right (this is the equivalent of scrolling quickly on your iPod). Once you get close to what you are looking for, you stop pushing in on the wheel and just rotate it left or right to select the correct item (this is the equivalent of scrolling slowly on your iPod).
This was not clearly documented in the manual but once you know this tip you can find things almost as quickly as using the iPod itself. Having said that though, I don't normally search for songs while the car is in motion because just like using a real iPod or cell phone it can be distracting.
Iggy888 is offline   Reply With Quote
Old 03-18-2009, 06:52 PM   #2
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Thanks yeah I have been playing with that but still don't see it go much quicker, I have to play with the settings more in order to get it in an ideal setting. I know there is a setting to change the scroll speed or something for that matter.
My Yaris: The Azure
andru47 is offline   Reply With Quote
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
