Old 03-18-2009, 02:40 PM   #1
Split
Drives: 2008 Yaris Sedan
Exclamation
^ that doesn't look lik eit would rub, but from what i've read, anything less than +42mm rubs. Hrm...
Split is offline   Reply With Quote
Old 03-18-2009, 05:01 PM   #2
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Can't always believe what you read...it's also lowered 1.75"
cm07yaris is offline   Reply With Quote
Old 03-18-2009, 07:31 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
only true for the front.... and it depends upon the tire set-up as well
I could tuck those +0 offsets' no prob!
Old 03-19-2009, 07:30 AM   #4
UKblackyari
Drives: yaris
im not sure about other setups but here is my experience. Im running +38 16x6.5 all round and i have 0 rubbing and im sitting on Tein Basics. Sorry for the pics but i dont have any from the side looking down the car.
UKblackyari is offline   Reply With Quote
Old 03-19-2009, 01:26 PM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
What size tires are you running?
Old 03-19-2009, 04:46 PM   #6
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
If you are not rubbing the crap out of the inner plastic fenders with the basics....
Then you are not driving fast enough !!
Old 03-20-2009, 01:05 PM   #7
UKblackyari
Drives: yaris
ill check the tire widths one i get home, but i know there 195/40 or 45. And i have never rubbed on this setup and believe me ive done some hard cornering in it and it still does not. The only time ive ever rubbed while havening the basics on was when i went to pick up the wheels with some friends in the back
Old 03-20-2009, 02:08 PM   #8
tonyg
Drives: yaris
so you're not rubbing because your running an improper tire size for the car? That would make your whole post irrelevant. You should be running 195/50/16 for a stock diameter.
You also say you have NEVER rubbed yet in the very next sentence you say you did rub. That’s contradictory.
So basically, yes you rub even though you run an undersized tire. If you ran a proper tire size you’d probably be rubbing all over the place.
tonyg is offline   Reply With Quote
Old 03-21-2009, 06:00 AM   #9
UKblackyari
Drives: yaris
for starters, im posting up my experience so theres no need to be an ass, just trying to help here. And i said that i only rubbed when i went to PICK UP the wheels. I was still running stock then and ive said that i have never rubbed ON THIS CURRENT setup. I also check with my mechanic before getting the wheels, he said it would be fine and id trust his judgment over yours any day of the week. Also from your post it seems your running with the same setup as me? if so then why not post your own experiences?
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
