Old 03-18-2009, 09:06 PM   #1
Klink10
Klink10's Avatar
With the factory stalk I would just like to be able to run fogs only.
Old 03-18-2009, 09:43 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The fogs turn off because the relay got the signal from the high beam ,
if your wheren't useing the factory stalk stopping this is real easy ,
but with the factory stalk you would need to experiment a little ,
start by looking at the wires on the back of the relay .
for pins means there will be at least 4 wires hopefully 5 or 6
or you could sit down for a couple of hours and read the service manual
for the wireing diagram. to find the wire you need to disconnect.
Just remembered ,check the back of the relay look for a white wire with black line .
99% sure that is the wire you need to disconnect.
TRD High Flow Oil Filters Jansen DIY / Maintenance / Service 20 05-25-2009 04:36 PM
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 11:06 AM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 09:37 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
