Old 03-18-2009, 10:45 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Originally Posted by dccurrent View Post
Thanks for the quick reply. I am already familiar with how to apply the material to the doors, but for the life of me I can't find not one source online that tells you how to apply it to the firewall. Do you know of any source that explains the process? To tell you the truth I am not even sure what constitutes a firewall to begin with!
For the wheel wells, what do you recommend? I know they make sprays you can apply, but there are so many it's very difficult to choose wisely when doing this for the first time with no experience.
I have also read that people applied material to the hood of their cars. Is this effective in any way in reducing cabin noise? Sorry for bombarding you with questions! Thanks again.
Firewall- basically, the part that starts as the floor board, but then ends up being vertical instead of horizontal. The sheet metal that divides the engine compartment from your feet/legs/knees.
You pull up the carpet from the floor boards, and get up underneath the dash as much as possible.... Not going to lie... its a bitch on toyotas.
for around the wheels... two things you can do, Buy sprays and spray it from the outside of the car (have to remove the wheels and jack up the car). On the inside you just lay down mat & foam if you have it too.
Old 03-19-2009, 06:29 PM   #2
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
On the 3-door liftback, the most 'bang for your buck' areas are in my experience:
The 'rear door' areas if you have the 3-door model. Basically the cavernous area behind the rear speakers, layer that down thick, and it's relatively easy to get that body panel off and back on again.
The rear hatch, actually. Once the above was handled, that was the next major area of noise we found. Didn't seal it up, wasn't needed. Just use lots of small bits, and the rap test a LOT. Suddenly it'll have enough mass in the right places and no more rattle.
Driver-side door.
Rear wheel-wells on the inside, though this requires taking the rear seat and rear seat-belts out including the 3rd-passenger one, which isn't that easy.
Passenger-side door. Make it more important than the rear wheel-wells on the inside if you usually have multiple people in the car.
If you've done all this, you have everything except the headliner removed already. Drop it, do the roof while you're in there. All this so far (excluding the doors) is one day's work for 2 rank newbs to accomplish easilly. One door fully sealed and foamed to hell and back is 2 hours work or so for a single person, again assuming rank newb.
Only thing I have left to do is yank the front seats out and the dashboard (I'll be doing that all at once since I need to run some in-dash stuff) and hit the firewall and front floorboards then, along with the passenger-side door.
WolfWings is offline   Reply With Quote
Old 03-19-2009, 08:46 PM   #3
dccurrent
Drives: Yaris 5 door Liftback
Thank you very much!
dccurrent is offline   Reply With Quote
Old 03-21-2009, 12:59 PM   #4
dccurrent
Does anyone know how much clearance there is between the window ans the outer skin of the door? I found some closed cell foam online and it comes in various thicknesses. I was wondering how thick I can go without interfering with the window rolling down.
You can find the stuff here:http://www.closedcellfoams.com/polyethylene.html
