Old 03-18-2009, 10:22 PM   #1
Puerto Rico FTW on modding cars. I gotta visit.
let's see, your goal is 13's: you did intake, throttle, header, exhaust.
Add an underdrive pulley and strip your car bare.
What do your wheels and tires weigh?
Get a larger throttle body.
Remove the A/C system completely. Down to 3 pulleys.
Run an electric water pump -- down to 2 pulleys.
Stiffen rear (or all) suspension so the car doesn't rock when you launch and shift.
Get a C-One rollstopper or (DIY) urethane your stock one.
TRD motor mounts.
Get a NITTO engine torque damper.
Design and fabricate an intake manifold.
Old 03-18-2009, 11:36 PM   #2
xen555
xen555's Avatar
Drives: 3 DOORS LB
if you come to puerto rico u can see maybe a tercel with a rx7 engine fwd...
mmmm why not a yaris with a rotary engine ???
so much power for a motor with only 180 lbs. and the size of a 5 water gals.
xen555 is offline   Reply With Quote
