Old 03-19-2009, 09:49 AM   #1
Looking through the electrical diagrams trying to figure it out... I'm interested, as I have dealer-installed aftermarket front fogs, and the cars here come with rear fogs stock...
It's pretty easy in theory, just need to swap a wire so that the fog light switch is energized when the parking lights are on (which they are in both high and low beam)
So here's what you'd need to do (in theory, someone please test this first with some spare fuses handy ):
Pin 4 is the input from the low beams and/or DRL module, pin 13 is the output from the parking lights.
Essentially you want to cut the wires going into pin 4 (depending if you have DRLs, there may be two wires, I'm not so sure), then short pin 4 to pin 13.
Give it a try!
Old 03-19-2009, 10:07 AM   #2
Attachment 20549
Give it a try!
I think you would want to use pin 10 (T1) rather than 13 (B1). B1 is the non switched leg, so the fogs would always have power. T1 is the switched output from the parking light switch.
TRD High Flow Oil Filters Jansen DIY / Maintenance / Service 20 05-25-2009 04:36 PM
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 11:06 AM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 09:37 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
