Old 03-20-2009, 02:08 PM   #1
tonyg
Drives: yaris
Originally Posted by UKblackyari View Post
ill check the tire widths one i get home, but i know there 195/40 or 45. And i have never rubbed on this setup and believe me ive done some hard cornering in it and it still does not. The only time ive ever rubbed while havening the basics on was when i went to pick up the wheels with some friends in the back
so you're not rubbing because your running an improper tire size for the car? That would make your whole post irrelevant. You should be running 195/50/16 for a stock diameter.
You also say you have NEVER rubbed yet in the very next sentence you say you did rub. That’s contradictory.
So basically, yes you rub even though you run an undersized tire. If you ran a proper tire size you’d probably be rubbing all over the place.
tonyg is offline   Reply With Quote
Old 03-21-2009, 06:00 AM   #2
UKblackyari
Drives: yaris
for starters, im posting up my experience so theres no need to be an ass, just trying to help here. And i said that i only rubbed when i went to PICK UP the wheels. I was still running stock then and ive said that i have never rubbed ON THIS CURRENT setup. I also check with my mechanic before getting the wheels, he said it would be fine and id trust his judgment over yours any day of the week. Also from your post it seems your running with the same setup as me? if so then why not post your own experiences?
UKblackyari is offline   Reply With Quote
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
