Old 06-14-2010, 04:45 PM   #1
Originally Posted by etheliters View Post
Why no mention of a euro 1.8 ts swap? Seems strange ...
ive talked about it....the 2zrfe swap, that is
started a thread or two about it on microimageonline.com
internet here not too quick at the moment, otherwise id find the thread links for you
Old 06-27-2010, 04:37 AM   #2
RXvedub
Drives: Echo
My first post. I have an Echo with a celica 1zzfe TRD supercharged and a 6spd. AEM FIC 91oct
I dont know if its interesting anymore or not
RXvedub is offline   Reply With Quote
Old 06-27-2010, 06:36 AM   #3
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Very nice setup. All custom work and definitely original. Good job.
Old 06-27-2010, 10:25 AM   #4
wraiths old car?
Old 06-27-2010, 01:39 PM   #5
RXvedub
Drives: Echo
wraiths old car?
Yes. I bought it as a chassis a few years ago. no motor stripped interior.
Old 06-27-2010, 01:49 PM   #6
Yes. I bought it as a chassis a few years ago. no motor striped interior.
i remember seeing the build for the s/c'd 1zz on echodrivers.com
nice to see its still in action...
Old 06-27-2010, 08:59 PM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Diddo!! I remember you put up a few build pictures and then left us in the dark wondering LOL.
Glad you posted it up
Old 07-28-2015, 12:58 PM   #8
Tarmat Terror
Drives: Ncp13-2001
hey i'm looking to do a swap i have in a 1nz-fe and i want to put in the 1zz did you have to modify anything or was it just a bolt in ? or did your echo come with that engine?
Tarmat Terror is offline   Reply With Quote
Old 08-21-2010, 05:17 PM   #9
Rozzzzz
Drives: Toyota vitz 2000
do the 2ZR-fe fit bolt on in first generation vitz..or what else option do i have
currently running 1.0 manual.....1.5 can be done but to swap 1.8
urgent help needed
i had the second thought about 2ZZ-GE which came in XRS corolla and celica..but am not sure first generation vitz engine bay is enough to fit this engine
power difference is alot but both 1.8
Rozzzzz is offline   Reply With Quote
Old 05-09-2011, 03:56 AM   #10
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
I know the size of the engine bay is pretty limited but what about an interesting mixed breed of Toyota and Chevy (It's been done before). Take a LSJ or LNF out of the Cobalt SS's , you would be losing roughly 400lbs on the low side of the weight spectrum and be gaining about 100hp. And the best thing about it is that they already run 14's consecutively and in our cars they would be in the 12's with just the swap.
Rob Cohen called, he needs his altezza's for the next Fast And The Furious
yarislady is offline   Reply With Quote
Old 05-15-2011, 12:38 PM   #11
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
Originally Posted by Sabretooth View Post
-RUMOR: That a 4age series motor has the same transmission housing as the Yaris, I have yet to find supporting information to confirm this, but it has been spread around enough to be considered possible.
there is a black yaris running around with a swaped 4age. dont know much about it though.
Scubaru Steve is offline   Reply With Quote
Old 06-06-2011, 11:42 AM   #12
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
1.8 Dual VVT-i 2ZR-FE
Im interested in this engine.. if it come out of a TS, whats the chances of getting it imported to the states? Does anyone know if this is a direct bolt in engine? Im sure some wiring will be needed being its from a RHD.. im curious about this.. being a former crx owner, i have done jdm swaps in honda's.. im very interested in this engine now..
Old 06-06-2011, 11:50 AM   #13
ilikerice
ilikerice's Avatar
1.8-liter 2ZR-FEThe Toyota 2ZR-FE is a DOHC, 16-valve, 1.8 L (1797 cc) engine also equipped with Dual VVT-i. This new engine is now replacing the 1ZZ-FE engine in most applications. Output for this engine is rated at 132 hp (98 kW) at 6000 rpm and 128 lb·ft (174 N·m) of torque at 4400 rpm for the Corolla, Matrix, and Vibe and 128 hp and 126 lb ft of torque in the Scion xD.
Specifications:
Engine Type : In-Line 4-cylinder DOHC 16-valve
Bore x Stroke = 80.5 x 88.3 mm
Compression Ratio : 10.0:1
Weight : 97 kg (without fuel)
Applications:
Toyota Allion (ZRT260/265)
Toyota Premio (ZRT260/265)
Toyota Corolla (ZRE142/152)
Toyota Auris (ZRE152/154)
Toyota Yaris (ZSP90) (Europe only)
Toyota Matrix/Pontiac Vibe (ZRE142) (North America only)
Scion xD (ZSP110)
got this from wiki... can someone explain to me what the bold stuff means? Also, the numbers i got underlined, whats the difference between these motors with these different engine codes?
Old 06-07-2011, 02:09 AM   #14
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Its so funny how the motor only weighs 213lbs lol
Old 06-07-2011, 05:02 AM   #15
ilikerice
ilikerice's Avatar
didnt even realize that.. dayum. i think the eclipse 4g63 block alone weighs that much. killed my back lifting that on the engine stand
Old 06-07-2011, 07:31 AM   #16
enviri
enviri's Avatar
Drives: 2010 Yaris
the bold stuff is the chassis code for the respective car.
Old 06-07-2011, 08:38 AM   #17
ilikerice
ilikerice's Avatar
ahh, ok, that makes sense. thanks enviri.
Old 06-07-2011, 12:36 PM   #18
iirc the 1nzfe is about 187lbs. blitz s/c and whatnot weighs about 35lbs.
ive looked into this swap as well, ilikerice. i think you need a passenger side engine mount from an xD as well as ecu and wiring harness. you'd want the 2zrfe intake manifold, throttle body, alternator (not sure we can reuse ours) and exhaust manifold (exhaust manifold should be for an xd).
from what i understand we can likely reuse our transmisison, but you'd likely want to pick up the flywheel for 2zrfe and likely a heavier-duty clutch. the xd exhaust manifold SHOULD also line up with our stock exhaust....
but nothing has been proven....yet
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
