Old 06-07-2011, 02:18 PM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
wow.. This is all sounding very do-able...
Everything you mentioned is actually very easy unless the engine mounts will need to be custom mounted to the body. If its just interchanging parts between the xD and yaris then I may have a project in the next year or two...
Im assuming the ecu will need to be from an xD also.. so some rewireing and sensor swapping will need to be done as well.. UNLESS... I can get a ecu from a Yaris TS..
I need wire diagrams now!
Old 06-07-2011, 02:44 PM   #2
you'll want the ecu and wiring harness from an xd
the problem on my car is that i don't have abs, so im not entirely sure what ill do about the speed sensor/speedometer...
but im supercharged now....i don't know that ill ever get to this swap
Old 06-07-2011, 02:28 PM   #3
Will someone please do a motor swap soon?
I'm waiting to die, and I can't do it until someone completes a Yaris motor swap. Please help me out on this.
Old 08-14-2011, 02:54 AM   #4
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
you can be the first Garm
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 06-07-2011, 04:29 PM   #5
ilikerice
ilikerice's Avatar
I will get to it.. and will probably boost it also.. my only concern is time and room.. but yea.. im gonna start lookin in the junkyards for xD's to strip things off.. hopefully a motor in the near future.. if thats the case this seems like a very nice and easy swap..
So, im looking at engines on ebay and can easily get just the block and head for roughly 650+250shipping... not a bad deal.. but they also got motors with everything for around $1000-$1300+shipping.. There is ALOT of Corolla 2ZRFE motors around.. I'm thinking going with either block/head setup and im assuming xD and Corolla/matrix are interchangeable components like alt, P/S, and A/c compressors.. can someone verify this?
Sorry garm.. your probably gonna have to wait a couple more years before you can die..
not only do i wanna wait for warranty to expire first (or really close to it), i need to do alot more research and im going to go ahead and start gathering the motor and parts.
Now... WHO WANTS TO BUY A GSX SHELL and A HALF COMPLETE MOTOR? lol
Old 06-07-2011, 09:54 PM   #6
enviri
enviri's Avatar
Drives: 2010 Yaris
btw here's a link for a 3S-GTE converted xD, im pretty sure since the XD and yaris share chassis, the install should be very similar. you can pm that guy for more info.
http://www.scionlife.com/forums/showthread.php?t=202097
Old 10-02-2011, 02:21 PM   #7
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Seen it in person,crawled under it and looked and honestly it fit very well,welding skills of course are needed to mount it....was a cool ride.
Old 06-08-2011, 05:01 AM   #8
ilikerice
ilikerice's Avatar
hmm.. interesting.. thats a badass xD.. Ill look into that more deeply.. thanks enviri
Old 06-10-2011, 07:58 PM   #9
enviri
enviri's Avatar
Drives: 2010 Yaris
or do you want a 3RZ (Tacoma 4cyl) inside a yaris?
Old 06-10-2011, 08:03 PM   #10
ilikerice
ilikerice's Avatar
absolutly not.. way too much fab work for my skills.. ill leave that to the skilled professionals. lol
Old 06-12-2011, 03:09 PM   #11
yarislady
yarislady's Avatar
Drives: 08 Yaris HB
Why the hell would they convert it to rear wheel drive.... :(
Rob Cohen called, he needs his altezza's for the next Fast And The Furious
yarislady is offline   Reply With Quote
Old 08-11-2011, 02:22 AM   #12
w7ist
Drives: 08 yaris lb
Because then it would be a proper car. ;)
The yaris would have a much bigger following if it had a proper set up like that.
Unfortunately its an ass dragger.
w7ist is offline   Reply With Quote
Old 08-11-2011, 04:57 AM   #13
ilikerice
ilikerice's Avatar
ehh, i agree and disagree with that one. look at the mini cooper S.. fwd, handles like a dream for only 180hp.
at autocross, side by side with a mini cooper.. I was taken back how close the wheel base looked. Yaris is just disigned to be eco friendly, not a corner hugger
Old 08-14-2011, 04:59 PM   #14
^ You mean "we", right?
Old 08-14-2011, 07:49 PM   #15
scioncrew
scioncrew's Avatar
Drives: SCION tC
lol i guess your wright WE can be the first.
Old 11-05-2011, 02:15 AM   #16
ArmyYaris
Drives: Blazin' Blue 2007 Yaris LB
would a 1zzfe fit in an 07 yaris? looking at a swap to do when i get back from deployment
ArmyYaris is offline   Reply With Quote
Old 12-13-2011, 06:24 PM   #17
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
i want this in a yaris
161bhp v4 based off the ls series
http://www.motusmotorcycles.com/kmv4.html
ttr125fan09 is offline   Reply With Quote
Old 12-13-2011, 07:11 PM   #18
Jedz123
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed
I recognize that! That's a motorcycle engine design. Cycle World did an article on it. Called the Motus MST-R
http://www.cycleworld.com/2011/07/22...pe-first-ride/
161 hp isn't anything too crazy for a motorcycle engine. from what i have heard that engine is a bit problematic hence why it hasn't gone into production yet.
The 1157cc motor that powers my Bandit 1200S dyno'd at my last dyno tune a respectable 134 hp to the wheel and 97ft/lbs of torque... That's wheel not crank ponies....Yes my bike is worked a bit but the bottom end is stock and the motor is the same cast as the one's that powered the frist GSX-R 1100s.
Now the Suzuki GSXR-1300R (AKA Hayabusa) 1340cc bumping out 178hp... Now that's a motor to drool about...
But I always hear motorcycle engines don't make the best swaps...
2008 Suzuki B-King
2001 Yamaha FZ1 (2005 motor swap)
1998 Suzuki Bandit 1200S
1983 Suzuki GR650
2008 Toyota Yaris 2DR HB (The Cage)
Jedz123 is offline   Reply With Quote
Official POLAR WHITE yaris thread wushumasterku Photo-Video-Media Gallery 477 08-27-2023 04:01 AM
