Old 03-21-2009, 03:17 PM   #1
427chev
Drives: 2009 Yaris with TRD parts
Originally Posted by roxy1 View Post
i think people w/ a scangauge have reported 3050-3100 rpms at 70 mph in the manual yaris.
That sounds awfully low.
I've driven a lot of cars and have never seen a small 4 cylinder turn revs that low at 70 MPH.
My 2.0 liter Sentra SE-R turned 4,000 rom even @ 80 MPH.
My 5 speed Yaris is "responsive" at 40 MPH in 5th gear; it's got be be carrying some pretty heavy gearing.
Have someone with a tach VERIFY what it is.
2009 Base model Bayou Blue 3 door hatch, 5 speed manual trans, Option Group D, factory floor mats, accessory mud guards, TRD shocks/springs/rear bar, TRD leather wrapped shift knob, Pioneer FH-P8000BT "double DIN" head unit & 4 Infiniti Kappa speakers, stainless steel license plate screws, Toyota stainless exhaust tip, enhanced driver's seat (professional upholsterer added spring mesh to lower seat cushion which DRAMATICALLY improved support/comfort and also built up lumbar region in seat back for more aggressive lumbar support. Seat Mod Cost: $125; the seat "feels" $350 better.)
427chev is offline   Reply With Quote
Old 03-21-2009, 03:28 PM   #2
SailDesign
Drives: .
Actually, it works out from the ratios at 3005 rpm.
At 40, it is 1720...
Old 03-21-2009, 03:30 PM   #3
427chev
Actually, it works out from the ratios at 3005 rpm. At least that's on a 2007
Yep, you guys are right on the money.
Check out this calculator. (Use the third calculator for manual transmissions.):
http://www.csgnetwork.com/multirpmcalc.html
Stock tire dia. (RE92s) is 23.9", 5th gear ratio is .82 and the final drive axle ratio is 3.72.
I'm surprised that this car is responsive as it is in 5th with that kind of gearing and such a small engine. Mine will easily pull 5th from 40 MPH with a bone stock engine and no power enhancing mods of any kind.
Tags
2009, advice, yaris
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Yaris 2009 Rudeshady Central and South America 10 12-23-2008 11:18 PM
2009 yaris grill bbdpbawler87 Cosmetic Modifications (Exterior/Interior) 6 12-12-2008 01:55 AM
