Old 03-22-2009, 09:44 PM   #1
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Good thing it was diesel in a gas engine and not vice versa.
Now that the diesel has been drained and the plugs replaced, keep running it and keep topping it off with premium to dilute any remaining diesel in the system.
Go to an auto parts store and have them read the code causing the MIL to be on (most auto parts places will read it for no charge). You may continue to see misfires or similar codes until it's fully purged of the diesel.
I support this message. To add to this advice, try to lay into the accelerator just a little more to use a little more than usual gas.^-^
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 03-22-2009, 09:48 PM   #2
la_scanner
Drives: 2007 toyota yaris
even with driving this since january 30th. and when i say driving it i mean nothing feeling wierd or off at all. just the fact that light is on.
la_scanner is offline   Reply With Quote
Old 03-22-2009, 10:05 PM   #3
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Go to advanced and have them clear it for you and tell you what it is.If it continues after 3 or 4 times of doing this then your problem is just going to be annoying.>.<
