Old 03-22-2009, 09:51 PM   #1
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
If it truly is the "Maint Light" it is just an automatic reminder every 5000 miles to change the oil. If it is any other light then it's tripped a code in the computer. Yes the Yaris uses four Iridium plugs that can last up to 120K miles. Any other plug would probably set of a check engine light. If it is the Maint. light you can reset it by making sure you are already on trip A when you turn the key to the on postion while holding down the reset button. You'll get 5 dashes that will start to flash and disappear after a few seconds.
UTVitz is offline   Reply With Quote
Old 03-22-2009, 10:41 PM   #2
la_scanner
Drives: 2007 toyota yaris
well isn't the yellow maitnece light the one that means malfunction of some sort in the engine. the red light, dont remember what they call that one, but i know that one is the one that means replace oil. now as far as the plugs go. the AUTOLITE Part # XP3924....could they be an issue. you mentioned the iridium. well i remember on the box those had iridium written all over the box.
la_scanner is offline   Reply With Quote
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
