Old 03-23-2009, 10:56 AM   #1
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Anybody tried a Megasquirt on a Yaris? If the ECU is rejecting the piggybacks maybe it's time to go standalone.
bearda is offline   Reply With Quote
Old 03-23-2009, 11:01 AM   #2
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
If you have the knowledge or time to wire it into your harness then it might be a viable solution, but I'm getting really tired of thinking Megasquirt is some kind of easy plug and play solution; it's not. I have a friend who put it in his Escort and it was a lot of work, the car runs fine now but it took a lot of time.
Octane boost wouldn't have that much effect on the A/F ratio unless he was running C-10 or better. Did they try to advance or retard the timing at all before he refused to run the car anymore?
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 11:10 AM
