#1 | |
Bathroom + Laptop = <3
did you install it on a yaris or an echo? |
#2 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Oct 2008
It was used as a piggyback in my echo when i still has the 1nzfe motor. Timing was still controlled via the stock ecu. The megasquirt took care of fuel. There was an issue trying to control the VVTi (this was back in 2006) but i am sure someone has figured it out by now. However controlling VVT on the blacktop motor wasn't an issue.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp 1987 Nissan Maxima - 40,000 original miles - Slammed 1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater 1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored 1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress |
resident senior
I think you peeps are looking in the wrong place . I bet if you put your stock exhaust back on you will find your HP and torque . Remember that thing called "back pressure" . You peeps have opened your exhaust too much , IMO .
Opening an exhaust too much will result in a loss of HP and torque . Either you need more airflow to fit your exhaust or you need to downsize your exhaust to create the proper back pressure . Want proof ? Just check out Noogie vs Poop setup . Poop has the larger exhaust and lower numbers .......
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#5 | |
I am going to dyno on a dynojet soon, run it to 6500rpms, and I can guarantee you it will be higher than 117hp on the dynojet. I do agree that my larger exhaust lost torque, but HP, especially in the higher RPMs, naw. But I am going to be running a 2" 24" resonator and a hi flow cat soon, so that will probably bring me some back pressure/torque back. |
#6 | |
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
I agree that a smaller pipe diameter may help, like 2 inches, but your terminology is wrong. Backpressure is never a good thing, you do not want back pressure for ultimate horspower. What you want is no back pressure but fast exhaust gas velocity, if you go too big on the pipe diameter you loose the exhast gas velocity and the coresponding hp and torque.
resident senior
Back pressure is a good thing . Some not alot . Without Backpressure(BP) there isn't any exhaust gas velocity . If no BP was a good thing all the real race cars would have exhaust gas being released straight from the exhaust port . ( Yes I realize that exhaust pipes also evacuate heat )
Try this , go turn on your garden hose . See how it flows ? To increase the velocity of the flow you can do 2 things 1. increase the volume of water or 2. partially cover the end of the hose with your thumb (creating BP) .
#8 | |
Backpressure does not create exhaust gas velocity, if the pipe diameter is too big the air moving down the pipe slows down and cools down which in turn makes the air molecules less active slowing down the flow. The reason race cars don't release at the exhaust port is because exhaust velocity actualy help draw air out of the cylinder head, but to get that you need the right diameter and length of pipe to create the exhaust velocity, what you don't want is any back pressure to slow down the flow, You have the right idea just not the right terminology, there are some really good papers on exhaust design and performance done by ASTM I belive, that tell you exactly that.
Break'em off some.
I didnt read the entire thread but think I have a decent idea of what is going on.
Here is the first thing I will say here: Comparing results from DIFFERENT DYNOS is not accurate and a waste of time. Different dyno manufacturers read differently, and ambient conditions change from day to day. If you have dyno results before and after a mod on the SAME dyno, generally the gain (or loss) you see is close to accurate. At this point, it looks like that if you want to fully realize the gains from a blitz SC, you will need addtional tuning. A fuel controller may work, but if timing is still retarded, you are only going to LOSE more power. We need to find out what that box does. Lets say all it does is retard ignition timing. Then I would say remove the bot, get a fuel controller and adjust the fueling curve, run cooler spark plugs and always run premium fuel. Adding a rising rate FP regulator is NOT a solution for a returnless car. There is really no mechanical fix to solve this particular problem. You are going to want a piggyback ECU or a reflash. You guys are not going to fix this with fuel system mods. I assure you, you are not running out of fuel with a ~30 HP gain. Peterpoop, Your exhaust is fine, I would not worry about it. If you can get something to view your ignition advance in the meantime, do so. |
| AFR running extra rich at WOT? | eTiMaGo | Performance Modifications | 15 | 03-10-2007 11:10 AM |
